suspension lift for begginers - JeepForum.com
post #1 of 9 Old 08-18-2011, 03:48 PM Thread Starter
kingodlid
99' TJ SPORT 4.0L V6
I want to put a 4 inch suspension lift on it and 33/or44" tires. I want to be able to do some beginner/mid level rock crawling. I could care less about putting it in the mud. I can do it with the help of some buds. My concern is axles, gear ratios, steering column, etc. Can anyone advise me on what I [U]really needto do for a 4" suspension lift and tires?
kingodlid is offline
post #2 of 9 Old 08-18-2011, 03:58 PM
tinyjeep
Welcome to the forums.
1.are you sure its a v6? we have inline6's
2.fill in your profile, not just put stock for everything.
3.try finding the tj wrangler faq/basics thread, everything is covered in there.
Off the top of my head...
you'll need a sye(slip yoke eliminator ) if your jeep's a non-rubicon. stock steering is fine for 33's. your gonna need adjustable control arms tool.
*edit*
http://www.jeepforum.com/forum/f9/tj...embers-722109/
http://www.jeepforum.com/forum/f9/wh...nt-one-854790/
http://www.jeepforum.com/forum/f9/bu...points-734737/
Originally Posted by The_Blacksmith View Post
Remember, it was a shark attack when you dove into the ocean to save a trapped puppy, while you were doing charity work to help clean up a local beach.
tinyjeep is offline
post #3 of 9 Old 08-18-2011, 04:08 PM
rda616
Oh, where to begin. For starters you have a 4.0 I6, not a v6. If you want 33" tires then a 4" lift is plenty, but you should do a sye and a cv drive shaft for the rear. You will need to do a front end alignment after the lift. And be sure you put the bump stops in or you will kill your fenders. You will want to regear the differentials and if you have a rear dana 35 it would be wise to upgrade to a super 35 kit, ford 8.8 or a dana 44 . If you want to run 44" tires you need one ton axles. You will need to highline the body amongst many other things.
rda616 is offline
post #4 of 9 Old 08-18-2011, 04:12 PM
alex211
1995 XJ Cherokee
I would do the Zone 4.5 combo lift or just a 3" zone lift. I'm installing a 3" zone lift on my TJ right now and it's a very nice kit, comes with everything you need.
IMO 4" is too much lift without replacing the stock control arms with adjustable arms, you're going to need a SYE with the lift too.
95 xj bone stock for now
alex211 is offline
post #5 of 9 Old 08-19-2011, 11:46 AM Thread Starter
kingodlid
My bad. Looong day flying. Excuse me, inline, not V6. Thanks for the help
post #6 of 9 Old 08-19-2011, 12:05 PM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
There's a very slight difference when running 33's or 44's.
TheBoogieman is offline
post #7 of 9 Old 08-19-2011, 12:20 PM
STIFLER
just need to add a super 35/30 kit and some axle trusses
0311/2531 USMC YUT
STIFLER is offline
post #8 of 9 Old 08-19-2011, 12:38 PM
Imped
Imped's Avatar
Unless you want to drop quite a bit of money, you aren't going to do 4" of lift properly. Most people are fine with a shrunken wheelbase, offset axles, and a fat transfer case drop. That's not doing it properly. It doesn't sound like you know why you need exactly 4" of lift so do some research and read some build threads. I think you'll quickly realize there's A LOT more to this than just slapping on some "4" lift kit" and some 33's. You'll also realize 4" is overkill for 33's. The lower you go, the better off you are. As for your axle ratio, axles, etc, it'd help if you'd fill out your profile. It's more 'applicable' than you seem to think.
OlllllllO
IndyORV
Imped is offline
post #9 of 9 Old 08-26-2011, 10:49 AM Thread Starter
kingodlid
Reason for doing this is 50/50, crawling/asthetic. It is my DD. It's got 190K. I'm really struggling with buying a new one. I've had her for over ten years and she's very dependable. I just want to be able not have any significant issues on the trail. I don't plan on putting her in a mud bog. Looking at what Imped originally had with the 2.5 seems more logical (being that this is my DD). I'll certainly updat the post as I make progress.
Thanks
axle , gear ratio recommendation , suspension lift
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 10:11 AM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 07:04 PM
body lift or suspension lift, no this isnt a stupid question!! lumpster TJ Wrangler Technical Forum 5 05-11-2009 10:19 PM
3" econo lift(cheap suspension lift tips) rivers edge TJ Wrangler Technical Forum 16 09-13-2006 06:57 AM
