Suspension height to fit my 33's ?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Suspension height to fit my 33's ??
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 05-03-2014, 01:46 AM   #1
redwrangler31
Hello all... I just purchased a set of 33x12.50's for my 98 TJ which is stock right now. A guy told me to go to the salvage yard & get the front coil springs off of a grand cherokee V8 & put them on the front of my wrangler & move my stock front springs to the rear. He said this would give me the 2.5-3" of lift needed to fit my 33's comfortably. Is this true?? Also, can I leave my factory shocks on it afterward without any problems? & finally, will I have to make any other adjustments in doing this, like lowering the transfer case or anything? (I am saving up for a proper lift kit but at the moment I only have about $50 left & have already purchased the coil springs from that salvage yard). Thanks for any advice y'all could give me!!
redwrangler31 is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 02:36 AM   #2
ex m38a1er
With just 2.5'' you might have to limit the uptravell with longer bump stops.
2.5'' OME with 1.25'' Zone body lift,is what I did.
" H TAN , H EΠI TAΣ"
'WHO DARES,WINS'
http://www.jeepforum.com/forum/f37/e...-my-tj-723762/
ex m38a1er is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 02:54 AM   #3
dadkinsemt
dadkinsemt's Avatar
1. I am unsure about the lift you will get or if you can use stock front TJ springs in the rear, if they do fit I'm guessing it will be a very stiff ride.
2. If you do get the 2.5 to 3 inches of lift you shouldn't have to drop the t-case.
3. You should replace the shocks to accommodate the lift.
4. What wheels are you putting those tires on? If they are stock wheels you will need spacers. Generally want 3.5inches of back spacing for 12.5
Hope that helps a little
Dusty
05 LJ rubicon
MY BUILD
dadkinsemt is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 04:42 AM   #4
joe_jeep
it will be close on the lift. it might still rub. u could add a 1" body lift.
u will need shocks. u will need wheel spacers.
good luck.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 07:28 AM   #5
rda616
Just buy a budget boost and some skyjacker hydro shocks.
rda616 is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 07:50 AM   #6
redwrangler31
Thanks for the replies! They are Pro Comp 33x12.50 mounted on aluminum "American Racing" wheels (they were previously on a 97 Wrangler with no spacers needed. The prior owner said they are Offset already, or somethin like that). I'm afraid to do a body lift right now because of a couple small areas of rust right around a few mounts that I may need to reinforce (weld plates)...so I am doing my best to raise it with what I have until I can afford the actually kit w/new shocks & all. Again thank u for the tips!
Unread 05-03-2014, 08:21 AM   #7
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Around 2-3" of lift would work for clearing your 33s.
You could add 2" coil spacers and keep the stock length shocks, but you will have limited downtravel because of the shocks being too short. This would cost around $60-80. I wouldn't normally recommend this, but it is an option for a cheap lift while you save for a more complete lift setup.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 08:26 AM   #8
tyvanwie
Do your current tires need to be replaced right now? If not, I would wait, save some money, and get a proper lift.
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 08:51 AM   #9
redwrangler31
Ye, my current stock wheels & tires need replaced very soon. Since I wanted 33's this summer, I found a great deal on a set 2 weeks ago, mounted & ready to go on the "ARE" aluminum wheels. I need to get them on soon now because of the current tire conditio.
I did also think of the 2" coil spring spacers, bit was told that 2" isn't enuff clearance for 33's (must be at least 2.5-3")
*****Heres a thought... What if I put the coil springs I got on the front, move the front OEM to the back, THEN put the 2" spacers on all 4 springs & try that?!? (Again, will the factory shocks be long enuff to leave on there once I do that??) ****** UGH....
Unread 05-03-2014, 08:56 AM   #10
tyvanwie
2" spacers and shocks is fine as long as you add enough bumpstop extension to keep to the tires out of the fenders.
Unread 05-03-2014, 09:18 AM   #11
redwrangler31
OH... Are they something that I can buy from my local auto parts store today? (Like Auto Zone or NAPA?)
Unread 05-03-2014, 09:26 AM   #12
rda616
No, but you can get a full set of spring spacers for $50. on eBay.
Unread 05-03-2014, 09:33 AM   #13
tyvanwie
The bumpstop extensions? For these you can either use hockey pucks, or preferably body lift pucks. Here's what I did:
Unread 05-03-2014, 10:43 AM   #14
Chase0808
I have a leveling kit on my jeep and it clears 33s
Sent from my Tj
Chase0808 is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 10:48 AM   #15
tyvanwie
Sent from my Tj
There's a difference between clears and running properly.
