Surging and poor performance.....fuel filter? fuel pump? - JeepForum.com
post #1 of 18 Old 02-05-2008, 05:40 PM Thread Starter
lwoods
Hey all, had an interesting day today. Boss needed my work truck so I drove my rig to Cincinnati and back for work today. Haven't had any problems out of it like this but on the way up, going up the hills it started surging like it was losing fuel or fire, pretty violently.
Started home and it did fine, then it started surging every now and then then progressively got worse. I realized at this point it was when I went past a certain point in the skinny pedal travel is when this got worse. Was thinking maybe gas, was down to half a tank, pulled over, filled up and dumped a bottle of fuel injector cleaner in. Ran fine for another 15-20 miles then started surging again, in almost a rythm, and I lost so much power that I couldn't even maintain 50 on I75, so I limped on the shoulder to the next exit, pulled over, cut the engine, topped off, engine was off about 4 minutes, started back up, everything was fine for about another 20 miles then it started again, but just slightly. By this point I was home so I haven't tried anything again.
Either way, it was directly related to the amount of travel on the pedal, and either topping off or shutting the engine off and turning it back on fixed it for a while.
The only other thing that I can think of being an influence is that it was absolutly pouring the rain most the whole time.
So, fuel filter? Fuel pump? Something else?
'97 TJ 4.0 5speed, patriot blue, spice top, lift is out of the mail and on the jeep. 4.10's, Dana 44 with LSD (Detroit going in there soon), 33x12.50 Cooper STT, 4" OME springs, DT shocks, 1" Body lift, JKS quicker discos, JKS adjustable front trackbar, RE adjustable rear trackbar, SYE and Tom Woods shaft. Smittybuilt SRC front bumper, homemade rear bumper, been stolen, flopped, and recovered. Duke sucks!
lwoods is offline
post #2 of 18 Old 02-05-2008, 05:48 PM
Piratejonh
Piratejonh's Avatar
Any codes? TPS, o2 sensor?
Jeep took another piece of my finger today...
Piratejonh is offline
post #3 of 18 Old 02-05-2008, 05:50 PM Thread Starter
lwoods
Nothing, everything checks out just fine! Idles just fine, everything, just seems to happen after 20 or so minutes, then a shutoff resets whatever it is.
lwoods is offline
post #4 of 18 Old 02-05-2008, 06:17 PM
Nonya
Replace the fuel pump assembly.
Nonya is offline
post #5 of 18 Old 02-05-2008, 06:42 PM
$lick
I wouldnt go that far yet, dropping the tank and changing the fuel pump is a job of its own.
The surging, or as i referred to as "bucking", happened to me in my jeep at random times after a deep water crossing trail ride.
Try the TPS, pop it off the back of the throttle body, spray some electrical cleaner in it, dry it out, or maybe pick up a new one < 35$.
1997 Wrangler 2.5L 5spd
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
Teraflex adjustable front trac bar
JKS Disco's
Axle specs:
Dana 30- Superior 4.88's
Detriot tru-trac locker
Dana 35- Superior 4.88's
Riding on:
33x12.50 BFG A/T
Black Cragar soft 8's
$lick is offline
post #6 of 18 Old 02-05-2008, 10:03 PM
Nonya
Its time for it anyway,but testing it woudn't hurt.Hook up a fuel pressure gauge at the fuel rail and drive it.Anything below 45psi means replace the pump.For it to surge it would be dropping much lower than 45 though.
Nonya is offline
post #7 of 18 Old 02-05-2008, 10:41 PM
rxl
rxl's Avatar
Check the cat. Put your hand up close to the tailpipe. Do you feel a thumping or just a hot breeze.
I bought "MY JEEP" for my wife
I bought "MY OTHER JEEP" for my daughter [she sold it]
I finally bought one for me
Canadian Jeep Club Member #7
99 GC limited
4.7 Quadradrive
97 TJ Sport
4.0 5 speed
99TJ Sahara
4.0 Auto
Sold to a life of blacktop
94 ZJ Limited
I6 Quadratrac
rxl is offline
post #8 of 18 Old 02-06-2008, 02:39 PM Thread Starter
lwoods
*bump* Would like to hear from someone who has experienced this problem. What happens when the TPS is going bad?
lwoods is offline
post #9 of 18 Old 02-06-2008, 02:45 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Erratic throttle response of an electrical nature that likely wouldn't limit any power whatsoever, not the type of problem you're having. It usually causes nothing more than an eratic idle and/or jumpiness when applying throttle.
Getting
Jerry Bransford is offline
post #10 of 18 Old 02-06-2008, 02:56 PM Thread Starter
lwoods
Thanks Jerry, so what do you think? Just like it's choking out when you floor it, and if you press down too hard like going up a hill it just surges from what it should be to no power at all and then back to fine again, over and over in about 1-2 second intervals. But then turn it off, start it back up and it's fine for a while.
lwoods is offline
post #11 of 18 Old 02-06-2008, 03:09 PM
Jerry Bransford
Administrator
Just for grins, let's re-examine the TPS which operates very much like the volume control on a radio. Without the engine running, cycle the throttle lever fully about a hundred times, which you could do via the accelerator pedal if you don't want to do it at the throttle body. If the TPS is merely dirty from getting worn inside, which is how they go bad, your symptoms will likely change; they may either get better or worse after doing this. Cycling the throttle that much will "wipe" the resistor inside and either temporarily clean it off or at least move the junk (carbon) around to a different location... any of which could change the symptom somewhat if indeed the TPS itself is bad. If there's a big change after doing that, you likely have a bad TPS. If there's no change, it's probably not the TPS.
This is just a way that might help isolate the problem either away from or to the TPS.
Getting
post #12 of 18 Old 02-07-2008, 06:07 AM Thread Starter
lwoods
Jerry,
It's hopefully gonna be a slow day at work, so I'll go out and give that a try before I head out for lunch today and we will see what happens. Thanks!
lwoods is offline
post #13 of 18 Old 02-07-2008, 09:53 AM
moparjunkee
Sorry
Sorry for hi jacking, but if I didn't know better, I would think that this was my rig being described. I am asking for the same solution and will be watching this thread close to see what the outcome is.
No matter how far you go, there you are.
moparjunkee is offline
post #14 of 18 Old 02-07-2008, 11:17 AM
Nonya
Test the fuel system before you waste anymore time on this.Only takes a few mins and you will know if you need a pump assembly.
Nonya is offline
post #15 of 18 Old 02-07-2008, 04:09 PM Thread Starter
lwoods
No problem moparjunkee, if you are having the same one stay tuned.
**Update**
I did as Jerry suggested, and I couldn't get it to do it again. I didn't get to drive far put I floored the skinny pedal and I haven't been able to do that in several days without it choking out once in a while. So it's still not definitive, but it's looking positive.
I'm back in the work truck tonight so I can't do any long range testing.
Will report back over the weekend.
lwoods is offline
fuel filter or fuel pump? jgillespie YJ Wrangler Technical Forum 6 03-23-2009 03:53 PM
Poor Contact with Fuel Pump Relay madams13 YJ Wrangler Technical Forum 1 08-16-2008 06:50 AM
fuel pump?fuel filter?relay? garoughrider YJ Wrangler Technical Forum 2 02-26-2008 06:23 AM
I think fuel pump/filter racer35 YJ Wrangler Technical Forum 6 02-13-2006 10:27 AM
HELP!! fuel pump or filter or both Caka TJ Wrangler Technical Forum 10 06-09-2003 02:09 PM
