Superlift 2.5 Inch Lift On 2000 Tj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Superlift 2.5 Inch Lift On 2000 Tj
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Unread 03-08-2003, 11:18 PM   #1
GENE
Just put a 2.5 inch lift on my 200 TJ.
I bought it from Quadratec.
I did it myself with alot of help from my wife.
Getting the new springs in, took a little pushing...... but we got them in.
The trailing arms were easy, old bolts out and new ones in.
The relocation bracket for the rear sway bar was easy, drill one 1/2 inch hole.
Adusting the linkage on the transfer case is very easy from the back side of the transfer case. Just loosen the linkage adjustment bolt and move the linkage forward about a 1/2 inch and then tighten the bolt down.
The transfer case lowering, is accomplished by lowering the skid plate and installing spacer pieces.
The job took friday night and saturday morning.
It is a good job for a beginner. Do it on a weekend and have a helper, and warm clothing (march in wisconsin ........).
Gene
2000 TJ, 2.5" superlift suspension lift, 31" bfg mud, Olympic rock rear bumper, ramsey 9000 winch, tomken gas tank skid plate, tomken steering box skid plate.
GENE is offline   Reply With Quote
Unread 03-09-2003, 02:50 AM   #2
DLoweinc
Great work!
Post a pic!
98 Grand Cherokee... Jack Stands, no front axle... Working seat belts!
DLoweinc is offline   Reply With Quote
