Superior Dana 35 C-Clip Eliminator Kit - JeepForum.com
post #1 of 61 Old 05-13-2008, 08:04 AM Thread Starter
Dravintoad
Dravintoad's Avatar
http://www.4wd.com/productdetails.aspx?partID=41125
I know it's fairly new, but has anyone used this kit yet?
What kind of cutting is required?
How do the 30 spline axle shafts work with the stock setup?
I was always interested in a Super 35 kit, but didn't want the rear locker and the cost to set it up, this seems to be a good, middle-ground type of kit, that I could do in the garage.
Any other info regarding the kit would be great.
Thanks
Nothing to see here.
Move along.
Dravintoad is offline
post #2 of 61 Old 05-13-2008, 08:40 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Thanks
The ad copy is incorrect. The old sales and marketing guy at Superior took the ad for the Super 88 and just substituted the words D-35 for Super 88.
It should read that there is no cutting, you have to drill two new holes in the housing end flanges and they supply the correct drill bit. The drilling is easy because you use the new housing ends as a guide.
The chrom-moly axles are 27 spline stock replacements.
It exactly a middle ground DIY in the garage in a few hours, kit.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 61 Old 05-13-2008, 08:51 AM Thread Starter
Dravintoad
Dravintoad's Avatar
Sounds good.
Thanks for the info Blaine.
Edit: It also states that the kit works with both disks and drums. Is this incorrect as well?
Move along.
post #4 of 61 Old 05-13-2008, 09:08 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Sounds good.
Yes that is incorrect, it only works with rear drums.
I am Savvy
mrblaine is offline
post #5 of 61 Old 05-13-2008, 09:18 AM Thread Starter
Dravintoad
Dravintoad's Avatar
Appeal to the masses eh?
Just a wild guess, but I'm getting the feeling you had a part in the development/testing of this.
Free samples, coupons, discounts?
Thanks again.
Move along.
post #6 of 61 Old 05-13-2008, 09:34 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You could view it like that, but reality is I did surveys on a few boards and asked the following question- If you have a Dana 35 rear axle, do you have drums or discs?
Out of every 10 who replied and there were several hundred, only 1 per 10 had discs.
It would take a lot more development to get the kit to work with rear discs and even then I'm not too sure it could be done without some unnecessary added width.
A part, yes. Part of the team that did it.
Thanks again.
I am Savvy
mrblaine is offline
post #7 of 61 Old 05-13-2008, 09:44 AM
Mayfair_Jeeper
Mayfair_Jeeper's Avatar
So does this mak the axel stronger on 33's? what is th4e purpose of the C Clip Eliminator?
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline
post #8 of 61 Old 05-13-2008, 10:01 AM Thread Starter
Dravintoad
Dravintoad's Avatar
- Stronger axle shafts
- Eliminates need for c-clips to retain axle.
If you were to break an axle shaft, with this kit, it would make it easier to get off the trail or at least to a better spot to work on the problem.
No tires falling off/axles sliding out.
No logs strapped to the side of your heep.
Move along.
post #9 of 61 Old 05-13-2008, 10:04 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's hard to quantify, but so far, there have been no breaks on 33's which is the intended market.
If there is a breakage, I'll be the first to update everyone.
I am Savvy
mrblaine is offline
post #10 of 61 Old 05-13-2008, 10:08 AM
Mayfair_Jeeper
Thanks All
post #11 of 61 Old 05-13-2008, 10:23 AM
jthompsn
Is there any way someone can post a link to the install instructions or send a copy to my email. I'm trying to guage whether or not this is an install I can handle on my own or will need a pro. Seeing the instructions will help. Thanks
2002 TJ Sahara, 4.0 I6, auto, d30/d35 with 3.73's, 33x12.5 bfg mt's, ome 2" lift and steering stabilizer, 1.25" JKS BL, JKS 1" MML, A to Z Fab ww2ww Rocker Guards, Teraflex adj front trac bar, AEM brute force intake, Magnaflow cat-back exhaust, optima yellow top, LoD front bumper with guard, LoD rear bumper with tire carrier, Delta Sky Bar, Delta Xenon Quad Bar H4 Headlamp conversion, Hi-lift...
jthompsn is offline
post #12 of 61 Old 01-25-2010, 03:44 PM
crateampscal
would you say that this is the strongest option for a dana 35? i am very interested in this
crateampscal is offline
post #13 of 61 Old 01-25-2010, 03:51 PM
never monday
yes.......
never monday is offline
post #14 of 61 Old 01-25-2010, 05:21 PM
02OlllllllOTJ
just purchased this kit with the 30 spline axles and arb. should receive it any day now.....
Originally Posted by 02OlllllllOTJ View Post
that much pabst blue ribbon will give you a hangover strong enough to slay a walrus
02OlllllllOTJ is offline
post #15 of 61 Old 01-25-2010, 05:28 PM
-Rudy-
Blaine, would you recommend this kit for 35's or would that be pushing the envelope? My presumed dream setup for this and the D30 would be the c-clip elims with a super 30 or chromos. Aussie in front and true-trac in the back with 4.56.
04 WJ Limited 4.7/QD: 245/70R17 Firestone A/T + Trimming
-Rudy- is offline
Superior Dana 35 C-Clip Eliminator Kit zbob TJ Wrangler Technical Forum 1 01-25-2010 05:22 PM
Superior M35 = S35 + c-clip eliminator? brjeep TJ Wrangler Technical Forum 4 12-29-2009 04:11 PM
Looking for Superior Dana 35 C-Clip Eliminator Bearing part number Maxxram TJ Wrangler Technical Forum 13 07-14-2009 01:25 PM
Superior Dana 35 C-Clip Eliminator Kit LEONEN TJ Wrangler Technical Forum 109 02-19-2009 05:07 PM
superior c clip eliminator cmc1 Wrangler General Discussion 0 08-13-2008 07:50 PM
