superior/alloy axle tube seals question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > superior/alloy axle tube seals question
JK Bumper System - Free Shipping + Cash RebateSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 09-20-2009, 11:02 AM   #1
yellowismellow
rubber duck sicko!
yellowismellow's Avatar
i know how to install these things, my question is....
for those of you that have installed the seals, did you remove the plastic disc on the stock axleshaft? im assuming yes, but dont want to remove it until i get an answer. thanks guys....
yellow and black with those red net things...
got some old TJ and YJ stuff for sale, PM me...
yellowismellow is offline   Reply With Quote
Unread 09-20-2009, 11:12 AM   #2
rescue6
Yes, I also use "Green Grease" brand of grease because it is waterproof for that added protection.
rescue6 is offline   Reply With Quote
Unread 09-20-2009, 11:13 AM   #3
Greg_Volkman
there is no way to install them without removing the plastic disc.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Unread 09-20-2009, 11:23 AM   #4
yellowismellow
rubber duck sicko!
alright thanks
also, all i have is red grease. is that ok?
Unread 09-20-2009, 12:49 PM   #5
Stu Olson
Stu Olson's Avatar
The grease I used on mine was quite red.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Unread 09-20-2009, 01:06 PM   #6
rescue6
Green Grease is a brand name that is waterproof. I really dont care the color just the fact that it is waterproof I guess I should have stated it better
Unread 09-20-2009, 01:43 PM   #7
stephenfarris
The blue marine grease works good too.
stephenfarris is offline   Reply With Quote
Unread 09-20-2009, 04:43 PM   #8
robncar
Yes, as said above, you remove the plastic pebble guard. We also used red grease. The only bad thing, if you can call it that, is the anodizing does not last. Instead of a nice red, we now have a somewhat pale color as fading has occurred.
[CENTER][SIZE="5"][COLOR="DarkRed"][B]DON'T FEAR THE RE-GEAR!!![/B][/COLOR][/SIZE]
[CENTER][B][COLOR="DarkRed"][SIZE="3"]______[/SIZE]
[SIZE="3"]|_____|[/SIZE]
[SIZE="2"](O|||||||O)[/SIZE]
[SIZE="1"]|______|[/SIZE][/B][/COLOR]
[SIZE="5"][][/SIZE]===[SIZE="5"]o[/SIZE]==[SIZE="5"][][/SIZE][/CENTER]
[SIZE="4"][COLOR="DarkRed"][B]RED JEEP CLUB MEMBER #430[/B][/COLOR][/SIZE][/CENTER]
robncar is offline   Reply With Quote
