Superchip and Scan Gauge2 - JeepForum.com
post #1 of 15 Old 08-17-2009, 09:06 PM Thread Starter
laxin15
Right now I have superchip in my 06 TJ and I run it on the 87 octane tune. I want to buy a gauge called a scan gauge 2. It a gauge that does a digital read out of a bunch of different things. http://www.scangauge.com/
What I wanna know is if it would be fine for me to stack the two on top of each other. I know your not suppose to stack programmers, but the scan guage isn't a programmer, I believe it just reads your ecu and stuff.
laxin15 is offline
post #2 of 15 Old 08-17-2009, 09:07 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
did you leave the Superchip thing connected? Aren't you supposed to remove it once you've flashed the program?
I have a ScangaugeII, its awesome
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 15 Old 08-17-2009, 09:21 PM Thread Starter
laxin15
yes it is removed once the program is flashed, but is it safe to also put the scan gauge on with it?
laxin15 is offline
post #4 of 15 Old 08-17-2009, 09:26 PM
Sobie
Bolt-on Maniac
Sobie's Avatar
I would assume it would be. The scangauge only reads data. So it should be fine.
Sobie is offline
post #5 of 15 Old 08-17-2009, 09:27 PM
Unlimited04
the worst that will happen is the Scanguage won't show certain data.
Useful Write-Ups:
Funny:
post #6 of 15 Old 08-17-2009, 09:29 PM Thread Starter
laxin15
i emailed the company to see what they would say but i am still waiting for a response
laxin15 is offline
post #7 of 15 Old 08-17-2009, 09:30 PM Thread Starter
laxin15
you dont think that it would ruin my computer or anything with both of them on it?
laxin15 is offline
post #8 of 15 Old 08-17-2009, 09:35 PM
Unlimited04
not at all. The Superchips thing can't change much of anything anyway. They're a complete waste of money since by federal emissions regulations they can only change the air/fuel ratio at wide open throttle, in open loop. Read more here. The Scangauge only reads data, if it doesn't get a reasonable signal, it doesnt show anything. Its all OBDII protocol, so you won't blow anything up dont worry.
Useful Write-Ups:
Funny:
post #9 of 15 Old 08-17-2009, 09:51 PM Thread Starter
laxin15
on my chip i have noticed a lil increase in power and i have noticed an increase in mpg, so in a couple months itll def be worth what i bought it for and my jeep feels like it runs a little smoother too. thanks for the advice i hope to buy the scan gauge2 soon.
laxin15 is offline
post #10 of 15 Old 08-18-2009, 05:28 AM
Neil F.
All the Scan Gauge does is read. It is not sending anything to the computer.
Neil F. is offline
post #11 of 15 Old 08-18-2009, 08:24 AM
storman113
I got my ScanGaugeII about 2 weeks ago. Be very careful if you set it to show you MPG and MPG average!! It is very depressing. You know the mileage sucks, but to see it live like that!!
I got mine with two cables. That way I can hide the wire behind the dash on both units. The Explorer is fine, I use it for long trips and seeing the MPG live helps with my heavy foot.
The intake air temp really blew me away! Gotta find some way to get outside air to the air box.
storman113 is offline
post #12 of 15 Old 08-18-2009, 08:28 AM
jgorm
jgorm's Avatar
Never use an obdii splitter unless it says you can, and that is typically only for the same brand of products. It can have conflicts in the communication protocol if you don't. Its fine to use the SC to program the ecu and then remove it and plug in the SG.
jgorm is offline
post #13 of 15 Old 08-18-2009, 10:34 AM
Robert J. yates
Do you have an aftermarket intake? If so, is the tube metal? If so...you can use this product to get your temps under control:
http://www.thermotec.com/cool-air-tube-heat-shield.html
Or you can use header wrap. I used the Thermotech product and it dropped my intake temps 50* on a hot day.
Robert J. yates is offline
post #14 of 15 Old 08-18-2009, 11:22 AM
storman113
Using stock intake. Looks like a good product. Will be looking into the header wrap. Thanks for the lead!
post #15 of 15 Old 08-18-2009, 12:03 PM
Robert J. yates
Those products won't do as much with the stock intake which is a thermoplastic material and used by the factory as it is more resistant to heat sink than the usual aluminum tube used by CAI manufacturers.
Superchip 3875 Ram4whldr TJ Wrangler Technical Forum 19 07-25-2011 05:19 PM
does the superchip product for tjs do anything 03rubiconMG TJ Wrangler Technical Forum 14 06-17-2009 03:40 PM
HyperTech vs. SuperChip tweetermx14 JK Wrangler Technical Forum 8 05-18-2009 08:04 AM
superchip khill8469 TJ Wrangler Technical Forum 3 04-04-2009 08:14 PM
Superchip??? thomsonc YJ Wrangler Technical Forum 1 02-24-2006 06:55 AM
