supercharger and turbo charger - JeepForum.com
post #1 of 21 Old 09-03-2006, 02:40 PM Thread Starter
ejmonkey3
just out of curiosity has anyone on here put either one on the 4.0. i know there is actually a quite a few companys doing this for jeep. just wanted to see if anyone has done it, or is, or thought about it. so yeah lets here some stuff about this guys
ejmonkey3 is offline
post #2 of 21 Old 09-03-2006, 03:04 PM
Conundrum
Conundrum's Avatar
Doing some drag racing?
Matt
2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat
1981 DeLorean DMC-12 VIN: 2953
Conundrum is offline
post #3 of 21 Old 09-03-2006, 03:06 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
there is a couple of guys who have done them, if for on road then turbo if for off then super, not worth it to most
RnEmOvr is offline
post #4 of 21 Old 09-03-2006, 03:10 PM
Binya Binya
Er hm. We're not all "guys" here.
Both my fiance and I have considered putting the Avenger Supercharger on the Jeep. We got an awesome quote from the guy for a new one after some haggling for about $1800. At the time, we have bigger issues to pay for, so we haven't done it yet. I'd love to do it though.
My fiance built his own turbo kit and put it on his Accord, and has a lot of power, and we figure ...hey, a little extra power won't hurt the Jeep. A few things will need to be modified first, and it'll use more gas, but what the hell.
So, down the road for me. =)
-Becca, RRT
*~*2002 Yellow Jeep Wrangler X*~*
*~*Five Speed*~*4.0 Litre*~*6 Cylinder*~*
*~*Flowmaster Exhaust*~*
*~*AEM Cold Air Intake*~*
Binya Binya is offline
post #5 of 21 Old 09-03-2006, 03:15 PM
ThisguyhasADD
new manifold, oil lines, turbo.... whole lot more not a bolt on ha.... i would like to see a huge front mount on a jeep though!!!!
ThisguyhasADD is offline
post #6 of 21 Old 09-03-2006, 04:05 PM
pwcracer
supercharger
I installed one on my mustang and it was far from bolt on, as I had to change or upgrade the following due to SC
Fuel injectors, fuel pump, coil, CAI, and Mass Air Flow sensor, then as a result of the added power, I had to replace clutch and upgrade the radiator. To tune all of this, I had to buy a unit that connects to the EEC (via laptop) and reprogram all the fuel and spark curves as well as reduce timing due to the added cylinder pressure. I added a wide band o2 sensor to monitor fuel air ratio to prevent engine from running lean.
I love tuning my car and it has turned into a hobby for me.
Id like one for my jeep as I feel needs more power, and it would give me a chance to compete with my bros classic bronco
My 8.8 build
pwcracer is offline
post #7 of 21 Old 09-03-2006, 04:19 PM Thread Starter
ejmonkey3
both i think would be much easier than on a mustang. add ons such as these on cars tends to be more difficult due to upgrading everything else as well. but yeah i wonder how the 4.0 would hold up you know under that kind of load? thats my concern cause if anyone does put that on i mean motor will be shot after 100k give or take.
post #8 of 21 Old 09-03-2006, 05:15 PM
BK'sTJ
i like the turbo idea more than a supercharger. a turbo is free horsepower driven by your exhaust but with a supercharger, it takes horsepower to make horsepower with the belt drive and whatnot. plus a turbo doesn't put a load on the engine at idle or when your not on the gas because it only builds boost under power. plus you get the greatest looks from the ricers when you pull up next to them and rev it up and they hear the blowoff valve.
Never forget that every day, to ensure your way of life; good men must do evil things
"I don't believe in repeat offenders, I believe in dead offenders." Ted Nugent
BK'sTJ is offline
post #9 of 21 Old 09-03-2006, 05:40 PM
KnightFire
KnightFire's Avatar
Go Here:
http://www.jeepforum.com/forum/f19/avenger-supercharger-install-286369/
http://www.avengersuperchargers.com/
http://www.rockcrawler.com/features/...ly/avenger.asp
http://www.jpmagazine.com/projectbui...t_4/index.html
This is what I'm going with next Spring:
http://www.kennebell.net/supercharge...wrangler40.htm
These should answer most of your questions.
HTH
Patriot Blue 4.0L
Cardinal Red 355CI
Flame Red 5.7L 4x4
Titanium Metallic 4.7L 4x4
KnightFire is offline
post #10 of 21 Old 09-03-2006, 06:33 PM
ni0h
There are kits to do both.
Mr Banks had his new supercharger kit on a 98, I think it was, out touring small shops, and I just happenned to be in the right place at the right time, and I got to take it out for a bit. It's set pretty mild for longevity. You'd definitely notice the improvement. For a ballpark comparison, it's about like being one gear lower than you are, but at the revs of the gear you're in. It would make a little bit of tire noise idling in first and stomping it.
ni0h is offline
post #11 of 21 Old 09-03-2006, 07:47 PM
Jeeples
Jeeples's Avatar
The main thing to watch out for if you are going to use a turbo (and an S/C) for that matter is heat.
Heat will kill a motor real quick, which is why a good intercooler is key to engine longevity, at least in a F/I application.
To me the 4.0 is the perfect candidate for Forced Induction. It has a low compression ratio from the factory, has been known to take abuse and last 100's of thousands of miles, and parts are relatively cheap for it as well.
As long as your motor is in good shape to begin with, I see no reason why a 4.0 couldn't handle between 6-8 PSI of boost, be it from a Turbo or S/C.
And all that trash about turbo's only being good on the road is just that. You won't have any lag issues at all as long as you properly size your turbo to the exhaust output of your motor. Plus the 4.0 has plenty of torque down low, so getting up and moving into the powerband shouldn't be a problem either.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #12 of 21 Old 09-03-2006, 08:47 PM Thread Starter
ejmonkey3
yeah id only get a turbo, nothing beats the sound of a blow off valve plus better gas mileage, not allways underload and the best part is there cheaper usuallly, plus its alot easier messing with it trying to get high or low boost instead of trying to mess around with belts all day.
post #13 of 21 Old 09-03-2006, 09:05 PM
LeeGro
the thing about a turbo though, would be the lag if, unless you got a small one, then your not really doing to much. sc have a pretty good powerband.
97 Sahara 5sp White
8.8 with tri-link w/ 4.56 gears, dana 30 with 4.56 gears, adj. control arms, herculined, 35inch kumho m/t, 3 inch susp. lift 1.25 bl., JKS quicker disco's
LeeGro is offline
post #14 of 21 Old 09-03-2006, 09:38 PM
Jeeples
Jeeples's Avatar
But see the I-6 makes enough torque to where if you're down low in the RPM band, you can get yourself up and moving pretty good.
That's the main reason I dislike turbo 4 cylinder motors, they pull hard up top, but it takes forever to get there.
Jeeples is offline
post #15 of 21 Old 09-04-2006, 12:15 AM
02tjsport
2014 KL Cherokee
Well put Jeeples.
The biggest concern with jeeps, is there is no tuning software out. You cant just plug in the ecu to your laptop like you can, per-say, on a mustang. There just isnt a market for it so noone makes it. Other than Hypertech, and then you can only do so much. Im sure there are ways to do it with preset 'chips' such as the one that kenne bell's blower comes with, or the EDGE chip.
So if you did a turbo, you couldnt just slap it together and go. Turbo cars are hard to tune anyway. Im not saying it cant be done, as i would love to build my own turbo kit, it could be done for relatively nothing. But then the tuning comes and you kinda hit a brick wall.
You dont necessarily need a new manifold for a turbo, you could run the turbo all the way back, have a rear mount turbo, intercooler upfront, some extra piping, and bada bing bada boom. Dont knock it because it has been done, (Well at least on a mustang.) and would save you from fab'ing a new manifold.
Blowers, in a sense, dont need horsepower to make horsepower. They DO, but the extra effort is so little, it doesnt matter. They CAN have Blow-off valves so if you like the sound of a BOV, then you can have it with a s/c too. And there is no fiddling with belts to achieve more boost. It is pulleys, so you get the pulley you need and put it on before you assymble everything.
And you CAN get good (in relation to stock) gas mileage with forced induction.
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline
Jeep Tj 4.0 Turbo Charger Grants99TJ TJ Wrangler Technical Forum 208 08-05-2013 10:08 AM
K&N Pre-charger? TJamz TJ Wrangler Technical Forum 11 07-25-2008 01:40 PM
turbo/supercharger eclipse27 TJ Wrangler Technical Forum 11 12-03-2007 12:48 PM
K&N air charger texasjeep05 TJ Wrangler Technical Forum 11 01-03-2006 02:30 PM
turbo or supercharger 80cj5 TJ Wrangler Technical Forum 32 07-27-2005 08:37 AM
