Quantcast Super Flex™ 3.5 Suspension System by Rubicon Express - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Super Flex™ 3.5 Suspension System by Rubicon Express
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 11-09-2008, 06:07 PM   #1
jberry
i have an 03 wrangler x. i want to be able to place 33/12.50's underneath and i'll use the jeep mostly for daily driving and occasionally for trailriding. i have a limited budget and i saw a Super Flex™ 3.5 Suspension System by Rubicon Express. is this a good lift that'll do what i want it to do? i'll take any help
jberry is offline   Reply With Quote
Old 11-09-2008, 06:10 PM   #2
jeff83
It's a very good lift by a very good company but if your on a limited budget and you won't be counting on this thing for heavy offroading why are you looking at RE?
build it, wheel it, break it, repeat
1983 CJ 7 (traded for TJ)
1992 YJ Renegade (sold)
1999 XJ Classic (daily driver)
1997 TJ Sport (building)
jeff83 is offline   Reply With Quote
Old 11-09-2008, 06:15 PM   #3
UTWeezul
will easily fit 33s, 35s with a 1" body lift. If you are on a budget, look at the 3" BDS kit. It will fit 33s. You might need a 1" body lift if you off road it.
Enjoy life to the fullest each and every day!
http://www.midsouthjeeps.com/
UTWeezul is offline   Reply With Quote
Old 11-09-2008, 06:17 PM   #4
BLK2000TJ
It's a very good choice. If it's for a daily driver I'd recommend the Rubicon Express Monotube shocks the ride with those shocks is better than stock in my opinion.
2010 JKU Rubicon 3.5" AEV , AEV Pintlers 35" KM2's , AEV Bumpers, AEV Hood / Snorkel
2008 JKU (Daily Driver)
2000 TJ Auto 4.5 RE Superflex ,35" MTZ 's , Warn ,Viking, LoD, RockHard,AEV, JKS, ARB's, Vanco Big Brake Kit ,Currie etc. etc.etc.
BLK2000TJ is offline   Reply With Quote
Old 11-09-2008, 07:00 PM   #5
Savvy
Savvy Off Road
Savvy's Avatar
Good kit! This is a great kit with adjust CAs and SYE and drive shaft.
http://www.4x4groupbuy.com/store/rubicon-express-re70003-superflex-combo-p-6662.html
Email me for the fastest response: gman@savvyoffroad.com
Follow us on Facebook FACEBOOK.COM/SAVVYOFFROAD
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
PM MrBlaine for Black Magic Brakes!
http://www.savvyoffroad.com
2006 LJ Unlimited Black Hole
2005 LJ Test Mule
2003 TJ Project Unrolled
2003 TJ Project Click Here
Savvy is offline   Reply With Quote
Old 11-09-2008, 07:13 PM   #6
jeff83
Don't need an SYE with a 3.5 unless you plan on going higher or plan on doing some hard offroading but still a very nice kit by RE
Old 11-09-2008, 07:44 PM   #7
RockRodHooligan
Under Construction
RockRodHooligan's Avatar
1989 MJ Comanche
But you may need to do a t-case drop
Another vote for the RE kit, go RE mono tubes, Bilstein, or OME for shocks. I think the OME are cheapest.
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
I seen a frog once that ate a rolypoly that locked onto it's tongue and I rescued it from starvation by removing the rolypoly.
RockRodHooligan is online now   Reply With Quote
Old 11-09-2008, 08:09 PM   #8
Savvy
Savvy Off Road
Savvy's Avatar
Only problem is the RE3.5 springs give you more than 4" of lift. You will most likely get vibes without skid spacers or a MML. At least the ones I have installed them on.
2005 LJ Test Mule
Old 11-09-2008, 09:26 PM   #9
rubidriver
rubidriver's Avatar
I dont think there is a probably about it. As you stated the 3.5 RE springs are more like 4". That is excessive without correcting driveline angles... even if its on a Rubicon. Its a certain that he will experience driveline vibes with out TC Drop, MML, and or rear upper control arms.
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 11-14-2008, 04:47 PM   #10
jberry
i'mm new at this can anyone explain what a skid spacer is and also whats a MML? will i need them
Old 11-14-2008, 05:05 PM   #11
RVA_TJ06
A skid spacer or a transfer case drop kit essentially drops your transfer case usually an inch or so down to create a better driveshaft angle. A motor mount lift does as it says, raises the motor to create a better driveline angle....
I had a T-case drop on my 3.5 SF kit and a MML.. I bought my kit from 4x4groupbuy mainly because it "came" with an SYE kit which I installed a few months later.
Finally paid off...
RVA_TJ06 is offline   Reply With Quote
Old 11-14-2008, 05:14 PM   #12
2005X
you will be better off getting the RE "4.5 lift with swapped in "3.5 springs. the "4.5 kit is more complete compared to the "3.5, you will be happier in the long run. plus you will have the "3.5 springs with a complete lift
www.youtube.com/kgries
http://photobucket.com/kgries
in the 80's.... we had Ronald Reagan, Bob Hope, and Johnny Cash. Now we have Obama, No Hope, and No Cash..
2005X is offline   Reply With Quote
Old 11-14-2008, 05:18 PM   #13
DaOne
x2. I wish I would have done this also, especially since I am now planning to upgrade to 35s.
However...if $ is an issue (it was for me at the time), the RE 3.5" lift is an excellent choice. I have been running mine for 5 years. It's been great on and off road
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline   Reply With Quote
Old 11-14-2008, 05:22 PM   #14
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Good advice given above, and you can't go wrong with that particular lift kit. Just avoid buying it with RE's base level twin-tube shocks which are such a stiff riding shock that it'll turn what could be a good riding suspension into one that will make you feel like you're driving a buckboard wagon. Instead, go with RE's Monotube shocks, OME (Old Man Emu), or less $$$ Skyjacker Hydro (NOT Skyjacker's Nitro which is too stiff for a Wrangler).
Enjoy, it's a fine suspension that will work well for many years to come.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Old 11-14-2008, 10:06 PM   #15
miguelitojeep97
if you are going to do ANY hardcore wheeling, then get some currie rear upper adjustable control arms. I have heard countless amounts of issues with these rubber bushings, as I have been dealing with them as well.
other than that I love my kit!
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline   Reply With Quote
Glock Forum
