Super Dana 35??? - JeepForum.com
post #1 of 22 Old 11-10-2007, 02:30 AM Thread Starter
TJamz
Super Dana 35???
I've heard about these super dana 35 kits. Is it worth it? How comparable is it to D44 in strength? Anyone ever use it?
TJamz is offline
post #2 of 22 Old 11-10-2007, 04:03 AM
j0nesy
waste. better shaft, still a weak ring gear.
if you want d44 strength, get a d44 .... alloy 35 shaft is better than stock, but the weak link is still weaker then a D44
j0nesy is offline
post #3 of 22 Old 11-10-2007, 08:26 AM
cvd
cvd's Avatar
Doesn't the locker that comes with S35 kits replace the ring gears?
cvd is offline
post #4 of 22 Old 11-10-2007, 08:51 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
No, the ring gear is part of the ring & pinion gearset and neither get replaced. What does get replaced is the Dana 35c's weak carrier and axleshafts. You're probably thinking of the spider & side gears inside the carrier but that whole assembly gets replaced by the full case locker (ARB Air Locker, Detroit Locker, or Ox Locker).
For 99% of the Jeepers on this forum, the Super 35 kit is a very good upgrade and with the locker it includes, holds up to some pretty serious offroading with 35" tires. One of the members here who has a very well built TJ with a Super 35 installed regularly takes his TJ through the toughest rock crawling trails imaginable including Johnson Valley without problem. Super 35 breakages are extremely rare.
Jerry Bransford is offline
post #5 of 22 Old 11-10-2007, 09:18 AM
UTWeezul
I've got a super 35 with a Detroit and I'm very pleased and happy with it. I run difficult trails all the time at Windrock and never worry about it breaking. I'm on 35s with 4.56s as well.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #6 of 22 Old 11-10-2007, 09:20 AM
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
I'm very happy with my Super 35. I have the Alloy USA version with the Detroit locker. 500 bucks used and I haven't looked back.
Guys that flog the crap out of their rigs deserve their breakages. Super 35 with some common sense will last you.
Sure, there's better options out there, but do we all really need 60's and Unimogs??
I know what and where I'll be wheeling. I don't need anything bigger than my S35.
Good Luck.
1948 CJ2a
Airborne4X4 is offline
post #7 of 22 Old 11-10-2007, 10:16 AM
MODUS
MODUS's Avatar
super35 axles is hard to busted.
w/35s and 4.88s i've busted almost everythink else exept my axles.
i am almost ready for an s44 axle upgrade and regret that i dint do it from the begining.
TJ '03 SAHARA EDITION
Thanks..
MODUS is offline
post #8 of 22 Old 11-10-2007, 10:32 AM
Airborne4X4
1948 CJ2A
Specifics? Tell us actually what you broke.
1948 CJ2a
post #9 of 22 Old 11-10-2007, 10:37 AM
MODUS
MODUS's Avatar
an entire s35 ox locker a year ago (can post some pics too..)
the much in evidence weak point......r&p
the only think i've never busted is my rear s35 axles
Thanks..
MODUS is offline
post #10 of 22 Old 11-10-2007, 11:12 AM
GzrGlide
GzrGlide's Avatar
Good Luck.
Bingo! What Airbrne4x4 said. Look around what others are using and breaking/not breaking in your area and that will tell you what you can reasonably run. The key like you said is to know where you're wheeling. People break d60s too. They break d44s too. It's much easier for people to blame "faulty" equipment than their own driving style.
We wheeled our TJ for 6 years with an open 35 on 33's and 4.88s and never had a problem. Now that we have a 30 spline s35 w/Detroit we're still not being stupid and expect this thing to last a long time.
Mike
<<< ya know ya want to!
98 TJ SE
RE 4.5SF with 3.5 springs & Tera QDFTs
Super 35 & Detroit in back w/4.88s
33x10.5 BFG KM2's
Cobra 75WXST w/4' Wilson Antenna
Warn M8000
(1) Rubber Ducky
GzrGlide is offline
post #11 of 22 Old 11-10-2007, 02:23 PM
Adventure Bob
Um, the super kit locker does replace the spiders since Jeep never made a 30 spine carrier for the 35. Last I checked my ARB and the OX in our other jeep used their own spiders and carrier.
For the guy who ate the OX, did you break the center pin? Were kinda tracking carnage since we work with the OX guys. I would love to get some pics of your destruction.
Adventure Bob
MOABJEEPER Magazine
Adventure Bob is offline
post #12 of 22 Old 11-10-2007, 03:22 PM
McLovin
The stock spider gears and carrier are removed, or REPLACED, with a 30 spline detroit, arb, ox, or ECTD.
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
post #13 of 22 Old 11-10-2007, 03:27 PM
MODUS
MODUS's Avatar
that was a full disaster
don't be a misunderstanding over here. ox locker served me for a year or some but was the first time that i've pushed it hard and broked.
but was me who broked it you know what i'm talking about....everythink can be broke
on the right side of the pic are marked numbers.
these are the parts that did't broke, everthink else was full replased by the ox guys through the local shop!
Thanks..
MODUS is offline
post #14 of 22 Old 11-10-2007, 03:39 PM
McLovin
A little bit of JB weld woulda fixed that right up
Thats the first super 35 carrier break I have seen. What tire size were you running and what was going on off road when it broke? Rearend bouncing?
McLovin is offline
post #15 of 22 Old 11-10-2007, 03:57 PM
Cooneys08JK
Cooneys08JK's Avatar
What is the Super 35's price range?? Obviously it depends on the type of locker chosen?
'08 Black 2door JK- DD
'99 Chilli Pepper XJ- Wheeler- BFG ATs, 2 " BB + bolt on stuff
Cooneys08JK is offline
Super 35 or dana 44? Coops TJ Wrangler Technical Forum 13 10-03-2008 10:19 AM
Super 30, or Dana 44 gbean120 TJ Wrangler Technical Forum 5 08-27-2006 12:36 PM
Super Dana 30 RLD831 TJ Wrangler Technical Forum 10 12-14-2005 08:36 PM
Super 35 or Dana 44 Mazdaboy YJ Wrangler Technical Forum 24 03-27-2005 09:58 PM
swap dana 30 to dana super 30 Gaiver173 TJ Wrangler Technical Forum 7 07-16-2004 11:26 AM
