Summer Top Set-up - JeepForum.com
post #1 of 5 Old 03-17-2007, 10:02 AM Thread Starter
JeeperAbe
Summer Top Set-up
What would u guys suggest to run in the summer instead of the hard top or soft top. I want something that will keep me dry...offer protection...but if i want everything off and that wide open feeling it doens't take long to take down. Thanks. I really want something that will keep everything the most dry though. Wat do you guys run? I live in northern illinois and we get some good rain storms so...
1997 Jeep Wrangler SE 2.5l 4 cylinder auto, Stock.
Mods to come: 2" Coil lift, 31 MTs, Bumpers, Lights, Skids
JeeperAbe is offline
post #2 of 5 Old 03-17-2007, 10:07 AM
ptowntj
ptowntj's Avatar
Safari top, thats what I'm going with! Don't forget the header channel...bestop makes it.
8 lug xj.
ptowntj is offline
post #3 of 5 Old 03-17-2007, 10:23 AM
Gjones
I just bought the bestop header safari top, it seams to adequately cover the top. With my hard door windows up it mostly seals the drivers compartment. Only problem i see is if it rains a ton it will no doubt run all over the back and flood the rear of the tub. But that's why we have drain plugs
Gjones is offline
post #4 of 5 Old 03-17-2007, 10:23 AM
RUB1CON
RUB1CON's Avatar
ptowntj is right on I have a safari top, bikini, windjammer and duster deck cover and I use my safari top the most but I also have a cab cover from www.jeepcovers.com and love it, if there is a big storm while I am at work I throw that on and it works great because the safari will not keep everything dry in the big storms
'03 Rubicon
RUB1CON is offline
post #5 of 5 Old 04-10-2009, 07:14 PM
SpiderWeb
[YT]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/xBOyvmnMzHE&hl=en&ap=%2526fmt%3D18&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/xBOyvmnMzHE&hl=en&ap=%2526fmt%3D18&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YT]
To buy your SW1, SW2 or SW3:
http://spiderwebshade.com/products.php
SpiderWeb is offline
5w-30 in the summer? JEEP-DADDY TJ Wrangler Technical Forum 14 06-07-2009 03:16 PM
In the summer, how often do you put your top up? BigCanoe Wrangler General Discussion 26 04-13-2009 08:35 PM
Summer Top rebelkid17 Wrangler General Discussion 2 03-19-2009 07:38 PM
5w or 10w oil for summer? eclipse27 TJ Wrangler Technical Forum 18 06-11-2007 03:52 PM
Summer top? Wrangler11 TJ Wrangler Technical Forum 1 03-16-2007 02:45 PM
