summer top - JeepForum.com
post #1 of 12 Old 06-03-2012, 07:30 PM Thread Starter
ClassicTj
summer top
anyone ever run a factory soft top without windows, duster, and windjammer. i dont have a safari top and i started running this setup for summer just wondering if the factory top will be more waterproof then a safari.
ClassicTj is offline
post #2 of 12 Old 06-03-2012, 07:35 PM
OpeyTJ
i would have to assume it would be at least somewhat
OpeyTJ is offline
post #3 of 12 Old 06-03-2012, 08:00 PM
JohnW720
i run the soft top without the windows off all summer. if you have the doors on when the rain is coming, roll up the windows and pull the seats up like you would when someone is climbing in the back and the seats will stay bone dry. and if the doors are off, keep a tarp in the jeep and throw it over the seats.
JohnW720 is offline
post #4 of 12 Old 06-03-2012, 08:07 PM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
I have both. I'll run the factory soft top without windows if there might be a chance of rain. It provides a lot more coverage for the rear passenger than the Safari top.
TJDaveX is offline
post #5 of 12 Old 06-03-2012, 08:15 PM
zjwn2
I usually run soft top with no back windows for most of the year if it rains and you have the doors on you stay pretty dry. I usually do not have a back seat in and have removed the carpet. We did not have a cold winter this year here so my jeep has been like this since january
zjwn2 is offline
post #6 of 12 Old 06-03-2012, 10:50 PM
TBombadillo
I also run the factory soft top without windows for most of the summer season. Works well to keep both sun and rain off of front passengers (wife is a Irish redhead with very fair skin...). However, if it rains without the windows zipped in I often will have some wetness of the top of the back seat and on the carpet above the wheel wells. The real challenge is road spray while I am driving on wet roads. Spray from other cars and my rear wheels can effectively, if slowly, soak anyone or anything in the back seat. I tend to throw my windows in the back seat if I am concerned.
The real reason that we can’t have the Ten Commandments in a courthouse: You cannot post “Thou shalt not steal,” “Thou shalt not commit adultery,” and “Thou shalt not lie” in a building full of lawyers, judges, and politicians. It creates a hostile work environment. -George Carlin
TBombadillo is offline
post #7 of 12 Old 06-03-2012, 10:56 PM
Johann2006
I tried to use the factor top, however, the sliders that mount on the back are worn and needed a bungie cord to hold one in place. Needless to say that looked very unkept. Have decided to go with a bestop. Only thing I don't like is the additional charge for the windshield frame kit.
Also, I noticed the noise was a bit excessive - flapping through the cabin. I know...it's a Jeep right!
Johann2006 is offline
post #8 of 12 Old 06-04-2012, 10:17 AM Thread Starter
ClassicTj
Thanks guys when I figure out how to post a pic from my phone I will. We have had two down pours and it's dry. I really like the look as long as the rear corners hold up with my highway driving.
post #9 of 12 Old 06-04-2012, 10:59 AM
TBombadillo
I found that my rear seatbelts caused most of the flapping noise. A couple of lightweight bungee cords to hold each belt to the roll bar worked well. I even found some all black ones so they blend in with the roll cage padding.
post #10 of 12 Old 06-04-2012, 11:37 AM
TJDaveX
TJDaveX's Avatar
Easy fix. I wrap bungee cords around the center of corner flaps to the roll bar. They keep the bottoms tight in the tub rail, keep them from flapping, and also take care of the seat belt flapping.
TJDaveX is offline
post #11 of 12 Old 06-04-2012, 12:45 PM
sheriff1680
I run that way most of the summer....just put the windows and soft doors in the back in case....
The top has held up fine driving it like that in the highway
2014 Wrangler Sport S 2 dr
1997 TJ, 5.2 Magnum V8, 46RE, NP231, 4:10's.....
I hear voices.
sheriff1680 is offline
post #12 of 12 Old 06-04-2012, 02:47 PM Thread Starter
ClassicTj
This is how I set it up
New Summer top help brentr31185 JK Wrangler Technical Forum 2 05-15-2012 02:57 PM
Summer Top Help hayleyjo_21 Wrangler General Discussion 9 03-20-2011 06:42 PM
Can I go all summer with NO top on? waterboarder JK Wrangler Technical Forum 27 06-02-2010 03:12 PM
Looking for a Summer top, what to go with? justanotherhemi YJ Wrangler Technical Forum 6 05-24-2008 12:54 PM
5w or 10w oil for summer? eclipse27 TJ Wrangler Technical Forum 18 06-11-2007 03:52 PM
