suggestions to fix or change my spot lights? - JeepForum.com
post #1 of 4 Old 06-28-2013, 06:39 PM Thread Starter
briffdogg
hi is it possible to clean the rust off my spot lights, and can i buy the inside linings and just change that or should i replace the whole light? and also s can holder?
briffdogg is offline
post #2 of 4 Old 07-01-2013, 01:03 AM Thread Starter
briffdogg
no suggestions guys? sorry for such a newb questions
post #3 of 4 Old 07-01-2013, 01:14 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Excessive rust inside can jeopardize the integrity of the ground. Just get some new lights. There are small IP68 rated aluminum housed LED's that'll put out the same lumens as your spots and last twice as long.
Ya know, if you want.
Luck Favours The Prepared
Anticanman is offline
post #4 of 4 Old 07-01-2013, 11:49 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
The lights can be rebuilt/refinished. I did the to the ones on my truck, but mostly because I already had the spare parts. If you wanted to redo the internal reflector try http://www.amazon.com/KC-Hilites-421.../dp/B000630D3A
Another option is have a local shop chrome plate them or even high temp spray paint may work.
RnEmOvr is offline
