Sudden Loss of Engine Oil Pressure At Idle - JeepForum.com
post #1 of 9 Old 08-26-2004, 02:42 PM Thread Starter
jreddish
Sudden loss of engine oil pressure at idle
I have owned a 1997 Wrangler with 4.0L engine for about 6,000 miles.
1. It has 75K miles on it and based on appearance and maintenance records appears to have been very well maintained with oil changes done religiously at 5K mile intervals.
2. The vehicle normally operates with 40 psi of oil pressure at 2K RPMs and about 210 degrees of temp.
3. At idle and when warm the car normally shows some where between 15 psi and 20 psi of oil pressure at about 700 to 800 RPMs.
4. I have over the last few weeks I have had occasions when while sitting at idle and with no apparent loss of engine speed the oil pressure will suddenly drop and the check gages light and alarm will sound. This condition will go away with a slight increase in RPMs.
Has anyone else experienced this and can anyone explain it or suggest a fix.
jreddish is offline
post #2 of 9 Old 08-26-2004, 02:56 PM
Grimmjpr
My 97' did that all the time......bad oil pressure sender.....
2012 JK Rubi - Cosmos Blue/5 speed auto
04 TJ Electric Lime Green Rubicon - Bunch of extras. Cha-Ching - Gone
97 TJ Lapis Blue Sport - Gone
Grimmjpr is offline
post #3 of 9 Old 08-26-2004, 08:27 PM
unlimiter
I agree bad sender, or a short in the senders wiring....mine did the same thing with 75,000 miles on it....
2004 Unlimited Metallic Khaki
Sendel 15 X 8 Deep dish Chrome Wheels
Goodyear Dura 12.5 X 33
2" RE BB
Stock Dana 44 Rear
Stock Dana 35 Front
Rancho Steering Stabilizer
Soft Top / Hard top
6" Pocket Style Flares
unlimiter is offline
post #4 of 9 Old 08-26-2004, 10:26 PM
RKHOWND
Yeah, you might have some loose connections in your cluster. Just take it out and clean off all the connections and make sure they are plugged in. That will probably make the problem go away.
Thanks,
Jack
RKHOWND is offline
post #5 of 9 Old 08-26-2004, 11:03 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
99.99999999999% it's just a bad oil pressure sender. They have a reputation for doing that at the worst possible time, scaring the bejeesus out of you... like it did to me at 1am on a long lonely deserted desert road. My TJ was still nearly new at the time and it made me think the engine was going to crap out on me 50 miles from nowhere. A new sender fixed it permanently... it's been fine for 110K miles now.
Jerry Bransford is offline
post #6 of 9 Old 08-26-2004, 11:11 PM
atxtj
atxtj's Avatar
Yep, Mine would drop to 0 psi at idle. Scared the crap outta me!! Replaced the oil pressure sending unit, and now it sits happy at 20 psi at idle.
Mine: 1998 TJ
SOLD...but not forgotten.
Hers: 1981 CJ-7
Under Construction.
atxtj is offline
post #7 of 9 Old 08-26-2004, 11:22 PM
odanny
odanny's Avatar
Thanks so much for starting this thread. I just had this happen TODAY for the first time on my Jeep, and I was wondering what was going on, although it is the lesser of two problems. At least it is a quick fix. Cool.
odanny is offline
post #8 of 9 Old 08-27-2004, 03:39 AM
bydasea
bydasea's Avatar
Same problem here except it has continued after replacement of the oil sensor. It only happens once in a while after the temp reaches about 210F and when ideling. The oil pressure is slow to response when the rpm is increased but usually runs 40 plus under road conditions. Water pump failed at 107K miles so replaced radiator and hoses while I was in there.
bydasea is offline
post #9 of 9 Old 08-27-2004, 08:42 AM
rjcress
rjcress's Avatar
another vote for bad sender
I had the same thing happen on my 97 TJ (2.5L) about two years ago. Although several people advised me that it was a bad oil pressure sender, I somehow reasoned that it was a bad oil pump and changed it.
That didn't help.
Shortly after the pump swap I started dumping oil as I was driving. It left a thick black cloud behind me. The pressure sender had ruptured and was spewing oil onto my exhaust manifold/pipe.
So, I'll second/third/fourth the votes for the sender as the offending item.
The good news is that those are cheap and take 5 minutes to change, if you are slow.
Jeff
rjcress is offline
sudden loss of power!!! help!!! ghost183 YJ Wrangler Technical Forum 2 09-29-2008 06:36 PM
Mysterious Oil Leak & Pressure Loss at Idle AlexTJ TJ Wrangler Technical Forum 14 03-27-2007 08:42 AM
sudden loss in MPG slowsi TJ Wrangler Technical Forum 1 11-23-2005 03:10 PM
Sudden loss of power? RafaelSmith TJ Wrangler Technical Forum 10 06-08-2005 08:32 AM
Sudden Loss of Engine Oil Pressure at idle jreddish TJ Wrangler Technical Forum 4 08-26-2004 08:12 AM
