Stupid simple hood part, can't find! - JeepForum.com
post #1 of 11 Old 11-10-2014, 09:23 AM Thread Starter
JeffBowser
I'm looking for the plastic bushing that goes on the prop rod hinge. Been googling all morning, I must not know what its called, because surely someone makes a replacement part.....
Sheesh, in the last 12 months I have had more plastic and rubber go on me. Just yesterday I replaced all my windshield washer hoses and connectors. Last weekend it was all my vacuum hoses. I'm guessing 17 yrs is the upper limit
JeffBowser is offline
post #2 of 11 Old 11-10-2014, 09:36 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
TheBoogieman is offline
post #3 of 11 Old 11-10-2014, 10:05 AM Thread Starter
JeffBowser
Link 1 is the retainer clip, not the hinge bushing. Link two is a different design for a different model Jeep altogether.
post #4 of 11 Old 11-10-2014, 10:10 AM
TheBoogieman
Deeply Disturbed
post #5 of 11 Old 11-11-2014, 04:48 AM
Jonny Jeep
Jonny Jeep's Avatar
Seeing this post reminds me I've lost both pieces of bushing off my hood prop. It's not something that's listed in the parts list so it'll need a little thinking about. I'll have to measure the required inside/outside diameters and see what I can come up with.
With the milder climate here my vacuum and washer lines seem OK still, but I now wonder for how much longer...
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #6 of 11 Old 11-11-2014, 01:30 PM Thread Starter
JeffBowser
Let me know if you come up with anything.
My rubber and plastic lines were all showing heat deterioration. Inside the cab were mostly fine.
post #7 of 11 Old 11-11-2014, 04:55 PM
Rubikahn
Rubikahn's Avatar
Have you tried calling Daveysjeeps? You could try calling Crown. Last resort would be to try the dealer to at least get a part number. GL
OME ZJ/LJ lift, 33" MT MTZ on AR-23 wheels, front and rear JKS trackbars, 1" seat risers, MORE 1" BL and MML, factory Ipod adapter. Light khaki jeep club #72
Rubikahn is offline
post #8 of 11 Old 11-11-2014, 06:46 PM
329892 - Deactivated
Guest
So the plastic/rubber parts have a ... 17 year shelf life. Forget about the wrecker where you might get a 15 year old part. My bet is Chrysler still sells brand new ones.... and how expensive could it be? Even if it is $17.00... thats only $1.00/year.
329892 - Deactivated is offline
post #9 of 11 Old 11-11-2014, 07:09 PM Thread Starter
JeffBowser
It's not a separate part. For $60 and up, I can buy a whole new prop rod, includes the bracket with captive bushing. I'm thinking it just plain ain't available, but I'm still hoping to spend $ versus $$
As for calling Davey's, well, billiebob is close - I don't want another 15yr old part.
post #10 of 11 Old 11-12-2014, 04:40 PM
Jonny Jeep
Jonny Jeep's Avatar
I fixed my hood prop, at least for now. I was trying to think where I'd find plastic top hat bushings of the size required and remembered my old AGM battery hadn't been weighed in, and was still in the garage. It has two 8mm posts on top of the battery and I'd put the caps off the replacement on there. I trimmed the ends off so I had a pair of flanged tubes, I then checked fit, too wide, and trimmed a bit from the circumference. With the flanges trimmed down too they do the job.
I had been looking at the sharpie marker in my toolbox and wondering if that would work, along with some clear PVC hose and possibly some PVC outer from electrical cable. Typing this I'm also thinking the glue lined heat shrink I have here at home would do a good job and not come off easily.
Here's what I've done. Might try the heat shrink next if this doesn't last.
post #11 of 11 Old 11-12-2014, 05:53 PM Thread Starter
JeffBowser
Hey, not a bad idea. I have a pair of those caps handy myself
