Stubby winch bumper for a TJ - JeepForum.com
 44Likes
post #1 of 108 Old 07-31-2017, 11:07 AM Thread Starter
Guy_Van_Horn
I'm looking for a good stubby winch bumper for my `99 TJ that is stoutly made by not heavy like a boat anchor. I would like it to not break the bank either. Have you got any recommendations? I noticed the bulldog bumpers are in an affordable price range. Anybody got any experience with them? Are they any good?
Thanks.
Sent from my SM-G920V using Tapatalk
Guy_Van_Horn is offline
post #2 of 108 Old 07-31-2017, 11:09 AM
biffgnar
biffgnar's Avatar
If you are concerned about weight look at aluminum options. There are several that are popular around here. They aren't necessarily cheap though.
Guy_Van_Horn likes this.
biffgnar is online now
post #3 of 108 Old 07-31-2017, 11:11 AM
Ross
If you want light and don't want to spend allot of money. Cut down the stock one. Lighter that the original and cost nothing except maybe a blade for the sawzall. Then get a winch plate.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #4 of 108 Old 07-31-2017, 11:15 AM
TJnBC
LOD stubby is a nice bumper. Had it on my previous TJ. I believe around $200 now.
Sorry not many pics of my old Jeep here at work
2006 LJR...the madness begins again
TJnBC is online now
post #5 of 108 Old 07-31-2017, 11:20 AM
Ironhead
thats what I did, lots of other places for upgrades before replacing something I hope to never use
Ross and Guy_Van_Horn like this.
Ironhead is online now
post #6 of 108 Old 07-31-2017, 11:32 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It's not cheap but it's real hard to beat the design and quality of Savvy Offroad's aluminum stubby bumper. Its higher cost is partially offset by the fact that it comes with a built-in winch mounting plate so you don't have to buy that in addition to the bumper.
This is mine...
Jerry Bransford is online now
post #7 of 108 Old 07-31-2017, 11:38 AM
TJnBC
here is a pic of the LOD bumper on a YJ (off LODs site)
The link is below...looks like an extra $120 for winch plate, so $329 for complete.
http://lodoffroad.com/products/jeep/...umper-431.html
TJnBC is online now
post #8 of 108 Old 07-31-2017, 11:59 AM Thread Starter
Guy_Van_Horn
Hey, thanks for the input guys! You've given me several great options to consider.
Question for Jerry:
Is this the one you got?
http://shop.savvyoffroad.com/Savvy-O...3plqscsfapp005
Also, is it safe to use the aluminum bumper as a lift point?
post #9 of 108 Old 07-31-2017, 12:06 PM
Ross
mine is cut wide enough to still hold lights. Mine has a Warn mounting plate.
Ross is online now
post #10 of 108 Old 07-31-2017, 12:07 PM
biffgnar
biffgnar's Avatar
It's bolted to the frame and your winch is attached to it. Hmmm.... I hope it is strong.
post #11 of 108 Old 07-31-2017, 12:11 PM
Jerry Bransford
Administrator
Since a winch mounting plate is actually only bolted through the bumper to the frame below, the bumper could be made of plastic or not even be there at all if you have a winch mounting plate.
Yes Savvy's bumper is more than strong enough for a winch, that bumper (with its integrated winch mount) is mostly used on trails where winch usage is common and actually expected.
Not to mention if you look at the stock bumper, to which many winch mounting plates are bolted through to the frame below, it is primarily made from thin sheet metal.
post #12 of 108 Old 07-31-2017, 12:12 PM
jgarden
I've got a stubby Currie bumper that id let go for $50. Looks very similar to the savvy bumper. Made out of steel. No winch mount. You would need to add the winch mount.
Bumper has been sitting outside for a number of years, but has never been mounted on a vehicle.
I won't ship it. Located in 91307 area.
Sent from my SAMSUNG-SM-G930A using Tapatalk
98 Wrangler
NRA Life Member
jgarden is offline
post #13 of 108 Old 07-31-2017, 12:19 PM Thread Starter
Guy_Van_Horn
Sorry I meant can it handle lifting the vehicle with a high lift jack. I've no doubt they are more than adequate to be used with a winch.
post #14 of 108 Old 07-31-2017, 12:20 PM Thread Starter
Guy_Van_Horn
Originally Posted by jgarden View Post
I've got a stubby Currie bumper that id let go for $50. Looks very similar to the LOD bumper. Made out of steel. No winch mount. You would need to add the winch mount.
I'm in 84663 area code, so probably not practical to come pick it up since I'm guessing you're somewhere in California? Thanks anyway.
post #15 of 108 Old 07-31-2017, 12:27 PM
biffgnar
biffgnar's Avatar
Which creates more force pulling a stuck vehicle, potentially up an incline and at an off angle, with a 9k lb winch or lifting up with a high lift?
