Quantcast Which is stronger? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Which is stronger?
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 06-13-2008, 09:12 PM   #1
4x4Mudmonster
1979 CJ7
Which is stronger?
OK so I am thinking about getting front and rear Dana 44s for my TJ. But I can't decide whether to pick the Mopar Performance Rubicon JK Dana 44, or the Parts Warehouse Dana 44. I was just wondering is the Mopar stronger than the Parts warehous, or is it the otherway around.
-Anthony-
4x4Mudmonster is offline   Reply With Quote
Old 06-13-2008, 09:17 PM   #2
jays-tj
When is it enough?
jays-tj's Avatar
What spline axles do each of them have in them?
5.5" RELA
NorCAl Crawlers
jays-tj is offline   Reply With Quote
Old 06-13-2008, 09:31 PM   #3
4x4Mudmonster
1979 CJ7
The front Partswarehouse has 30 spline, and the rear has 33 spline. And the splines on the Mopars are...I don't know those.
-Anthony-
Old 06-13-2008, 11:06 PM   #4
rmack
do you know that the jk dana 44 is not a direct bolt in?
rmack is offline   Reply With Quote
Old 06-13-2008, 11:20 PM   #5
2005X
i would save the money from the front D44 and just add some cromoly shafts. and i think the JK 44 is gonna be alot more work than need be, go with the direct bolt on from a TJ rear D44. thats my setup. Tj D44 with cromoly and D30 with cromoly and im running 36s with no issues
www.youtube.com/kgries
http://photobucket.com/kgries
in the 80's.... we had Ronald Reagan, Bob Hope, and Johnny Cash. Now we have Obama, No Hope, and No Cash..
2005X is offline   Reply With Quote
Old 06-14-2008, 10:22 PM   #6
4x4Mudmonster
1979 CJ7
I might do that, and then save up the money to get the D44 front...but I like the cromoly shafts for the front...thanks for the advice
Yes I do know that.
-Anthony-
Old 06-14-2008, 10:28 PM   #7
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I'd avoid any D44 front axle that used the same 297 or 760x u-joints the factory D30 uses. That's the weak link so you're not really gaining usable strength. Not to mention the factory front Dana 44 uses the same axle tubes, u-joints, knuckles, and inner/outer C's as the D30 does.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 06-14-2008, 10:34 PM   #8
4x4Mudmonster
1979 CJ7
Well these are supposed to be stronger than Rubicon axles...at least thats what 4WD hardware says...
-Anthony-
Old 06-14-2008, 11:36 PM   #9
elkfan2
elkfan2's Avatar
Because they come with chromoly axles.
elkfan2 is offline   Reply With Quote
Old 06-15-2008, 12:11 AM   #10
jays-tj
When is it enough?
jays-tj's Avatar
just my opinion but I would think that if you upgrade the shafts the Partswarehouse one would make it a stronger axle. When I bought my front D44, I upgraded the inner and outer to 30 spline Chromoly and I bought my rear D44 I upgraded to 35 spline chromoly. One thing I wish I would have done for the front is looked for a high pinion. My front driveline hits and rubs the RE belly pan when I'm articulating.
Does anyone know if the front jk D44 is a high pinion?
5.5" RELA
NorCAl Crawlers
Old 06-15-2008, 12:46 AM   #11
tjbrotha
sorry to hijack, but i've always wanted to know (since no one ever talks about it) what does the spline count matter, and how can the higher number affect the axle?
and don't forget to wave !
97 I4 TJ SEDone 8/13/07: DPG Ultimate Suspension kit: DPG Trailgunner Coils, Old Man Emu HD Shocks, JKS 1.25" BL + 1" MML, JKS Front and Rear Adjustable Track Bars, JKS Quicker Disconnects, 31" BFG A/Ts daily driven 33" BFG A/Ts Wheelin, Personally made Hand Throttle, Airaid air filter, goin for more asap
Asking a Jeep to be fast is like asking a brick to fly.-Airborne4X4
tjbrotha is offline   Reply With Quote
Old 06-15-2008, 09:17 AM   #12
Unlimited04
Unlimited04's Avatar
http://www.fourwheeler.com/techarticles/drivetrain/129_0501_4x4_truck_axle_tech/axle_strenght.html
The higher the spline count the more surface area present to distribute torque, and therefore the stronger the axle shaft.
Unlimited04 is offline   Reply With Quote
Old 06-15-2008, 09:23 AM   #13
spyder6
Just violated my Parole
spyder6's Avatar
yes it is, according to the engineers
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 06-15-2008, 10:24 AM   #14
Jerry Bransford
To that, a higher spline count also gives you a larger diameter axleshaft which is the main reason it is stronger.
Getting Savvy...
Glock Forum
