Stripped torx bolt - JeepForum.com
post #1 of 32 Old 04-04-2008, 04:15 PM Thread Starter
ohfourtj
Stripped torx bolt
Is there anyway to get a stripped torx bolt out of the side of my 04 tj? I've heard drilling but i'm not sure how and how would i rethread the hole for a new bolt?
ohfourtj is offline
post #2 of 32 Old 04-04-2008, 04:17 PM
alvinl
alvinl's Avatar
Use a dremel and cut a slot in it so you can get a regular screw driver on it. Or go to the hardware store and buy a screw extractor. Ill see if I can find a link.
Something like this: http://www.sears.com/shc/s/p_10153_1...id=00952154000
alvinl is offline
post #3 of 32 Old 04-04-2008, 04:19 PM
jb4
if the extractor doesnt work and you drill it out you'd buy a tap n die set to cut new threads into the nut...
where exactly on the side is the torx screw? is it part of the windshield hinge?
jb4 is offline
post #4 of 32 Old 04-04-2008, 04:30 PM
Hilljack27
Hilljack27's Avatar
Same thing happened to me when I was putting on new door hinges. I tried all the techniques mentioned above but the bolt was so stuck in there it wouldn't budge. So I took it to a local body shop and they took it out for like 12 bucks.
2000 TJ Sport
3" BDS Suspension Lift
1.25" JKS Body Lift
33" x 12.5" Mud Terrains
Aggressive style but a practical everyday driver.
Hilljack27 is offline
post #5 of 32 Old 04-04-2008, 06:26 PM Thread Starter
ohfourtj
yea its on the side not sure if it is part of the windshield but im trying to put on mirror relocators, i'll try the dremel first though, thanks for the help
ohfourtj is offline
post #6 of 32 Old 04-04-2008, 06:29 PM
kloppk
The torx bolts in the windshield have RED locktite on them.
You need to heat them with a torch which softens the red locktite.
The bolts will then come out very easily.
I just went thru this last weekend.
kloppk is offline
post #7 of 32 Old 04-04-2008, 06:34 PM
Lawrence
Not need to torch anything. The trick with torx (red loctite or not) is to make sure you keep your bit perfectly square to the bolt head. If you have an impact gun, they will come out nice and clean every time.
Lawrence is offline
post #8 of 32 Old 04-04-2008, 06:40 PM
alex71
I would weld a nut to the head of it before i drilled it out. I welded a nut to all mine and got them out easy
2001 jeep wrangler sport / Waggy 44 /FORD 8.8. lockright/ 4.88 / 3/2'' lift,Stretched to 100.5/ Warn x8000i / 35in BF KM2's / AtoZ rockers, cage,/ Poison spyder crusher corners.
Vote for TJOFTY!
alex71 is offline
post #9 of 32 Old 04-05-2008, 07:13 AM
KKiowaTJ
X2 I have this problem every time i touch the jeep, So now i buy new bolts to replace the junk torx head bolts. As said above, Weld a nut to it, And be done, Not work putting effort into somthing that can be taken out in less than a minute when you weld a nut to it.
MOPAR!
KKiowaTJ is offline
post #10 of 32 Old 04-05-2008, 07:18 AM
nj tj
i had recently changed my tailgate hinges and stripped my torx bolts. I managed to drill the heads out with the same size bit as the head. Once i drilled the head out the leftover stud threaded right out. This may not work in all situations but it worked for me.
nj tj is offline
post #11 of 32 Old 04-05-2008, 07:27 AM
Heyduke
Now that it is stripped out....the proper size one of these will do the trick.
http://www.mytoolstore.com/hanson/hanson.html
Heyduke is offline
post #12 of 32 Old 04-05-2008, 08:31 AM
Fred99TJ
I have welded a nut to the head and removed it that way
Built 92 XJ For Sale
Fred99TJ is offline
post #13 of 32 Old 04-05-2008, 09:36 AM
27mtaylor
I used my dremel to cut the sides off the bolt. Then I was able to use a pair of vise grips to turn the bolt.
"97 TJ, 4.0, 3" Black Diamond Suspension, 2" body lift, JKS disconnects, Borla Exhaust, 35x12.50x15 BFG MT's, G2 Dana 44 Rear Axle Detroit Locker
27mtaylor is offline
post #14 of 32 Old 04-05-2008, 08:58 PM
walldk
I feel your pain
I had the same problem doing the same project. The forum gave me the same advice. After I trashed the torx head I cut a slot in the head with a carbide bur in a dremel. We used an impact driver and an air impact wrench with a large flat tip impact bit. It did not budge. We tried to apply heat but found that getting heat to tranfer down the torx is tough without damaging your paint. The one that is stuck on mine can be reached from the inside through the glove box hole and never got hot enough to make me take my finger off of it. We used a small butane torch and shot the flame through the center of a bronze bushing. I did not try to weld a nut to the head. We decided that the bolt must have been cross threaded during installation and gave up before doing any more damage. I used some 3M two sided foam tape between the mirror bracket and hinge surface. I put a stainless steel bolt and flat washer in the other hole. It has been about 3 weeks now and I have not had any problems. I need that $12.00 body shop fix.
walldk is offline
post #15 of 32 Old 04-05-2008, 09:37 PM
xltj
Whatever you do, do not buy an easy-out. They will break, and then you will have to deal with both a stripped/stuck torx bolt and a broken easy out inside of it. Ask me how i know!
xltj is offline
Stripped Torx bolt h2osprt YJ Wrangler Technical Forum 2 04-08-2009 09:01 PM
Torx Bolt is stripped! Help! BearsJeep TJ Wrangler Technical Forum 5 11-28-2008 06:23 PM
Help with stripped Torx bolt Jonman03 TJ Wrangler Technical Forum 19 05-29-2008 08:14 PM
stripped torx bolt...HELP LilViper95 YJ Wrangler Technical Forum 11 12-26-2004 09:50 AM
Stripped Torx bolt Rastahmann TJ Wrangler Technical Forum 2 05-06-2004 08:04 PM
