Quantcast Stripped T-case skid NUTs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Stripped T-case skid NUTs
Old 02-18-2008, 01:58 PM   #1
young yeller
is it recommended to attempt to TAP the welded nut inserts that the t-case skid plate bolts run up into in the frame? one's clearly stripped and another is likely on its way out.. aside from cutting into the frame and re-doing them all together, is this a viable option, or will it likely just spin the nut?
anyone do this before??
2001 TJ Sport-Yellow l 4.0L/5sp
Yellow Jeep Club Member #5
young yeller is offline   Reply With Quote
Old 02-18-2008, 02:02 PM   #2
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
It's worth a shot with a hand tap tool.The larger diameter might hold up to that.If not,use a slightly larger diameter self tapping screw/bolt after drilling it out a bit.
TheBoogieman is offline   Reply With Quote
Old 02-18-2008, 02:59 PM   #3
daveg13
I used a 9/16" tap and did one of mine. Didn't have to drill anything. The hardest part was finding a 9/16" tap and bolt locally. Every hardware store that I went to only carried up to 1/2" bolts. If I have to fix another one, I'll replace the nutserts. Here's a good how to:
http://www.jeepforum.com/forum/f9/nutsert-transfer-case-removal-install-390635/
daveg13 is offline   Reply With Quote
Old 02-18-2008, 03:40 PM   #4
young yeller
http://www.jeepforum.com/forum/showthread.php?t=390635
Thanks for the info guys, and this writeup is excellent.
Glock Forum
