Stripped oil pan drain plug - JeepForum.com
post #1 of 7 Old 10-05-2006, 12:43 PM Thread Starter
Brazos
I overtightened the drain plug in my oil pan and stripped the threads. Outside of buying and installing a new oil pan what are my options? I can't be the first fool to do this.
Thanks,
Brazos
1978 CJ5 & 2006 TJ Unlimited
Brazos is offline
post #2 of 7 Old 10-05-2006, 12:46 PM
Crashnburn80
Crashnburn80's Avatar
Well as I am sure you have learned you only need to hand tighten the plug with just a little turn of a wrench to make sure its snug, nothing more. You can probably get a tap to run new threads in your pan. Just go to a sears and they will have them in their tool department.
edit: be aware this will put small metal shavings in the base of your oil pan. You should flush with some oil or get a magnitized plug or something afterward.
Crashnburn80 is offline
post #3 of 7 Old 10-05-2006, 12:48 PM
bobbert350
bobbert350's Avatar
yea need to retap it u dont neet to tighten it that much ur tightening it into sheet metal....u really had to crank it down
bobbert350 is offline
post #4 of 7 Old 10-05-2006, 12:51 PM
AlTheKillerr
AlTheKillerr's Avatar
i went to walmart and said that they messed it up (which they did) so they pulled in my jeep and took a look at it and gave me one for free.
Photographer
AlTheKillerr is offline
post #5 of 7 Old 10-05-2006, 01:05 PM Thread Starter
Brazos
I knew better
I knew better. I had a truck a few years back that had a loose drain plug when I went to chage the oil. No oil was dripping out but I was able to remove the plug with my fingures. Every since then I have been scared not to tighten the plug as much as possible for fear it would viberate out and dump all my oil out on the highway. I this case I did not feel like I was tightening too much and it wnet loose on me. Oh well.
Brazos
Brazos is offline
post #6 of 7 Old 10-05-2006, 01:23 PM
Varnish
Varnish's Avatar
Have you verified its the threads in the pan rather than the bolt? I had the bolt threads strip off on a ford 302 but the pan threads were fine & just a replacment plug was needed.
'98 TJ, '06 LJ, '88 YJ
Varnish is offline
post #7 of 7 Old 10-05-2006, 01:51 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
You should tap it one size larger but in the meantime at the auto parts store they used to sell a plug that went through the hole and and sandwiched two rubber seals together.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
Spark Plug & Oil Drain Plug Torque Specs bfewkwa TJ Wrangler Technical Forum 7 08-28-2009 06:19 PM
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 03:26 AM
Oil Drain Plug Size for FRAM Sure Drain Thunderstrike JK Wrangler Technical Forum 12 02-25-2009 05:45 PM
large drain plug and fill plug stu'sjeep TJ Wrangler Technical Forum 4 04-21-2008 08:14 PM
Stripped Tcase drain plug DavidC TJ Wrangler Technical Forum 7 07-18-2007 01:29 PM
