Stripped a nut from one of the four tranny mounts. how do i get it off now????
#16 | ||
TITS
#17 |
That's Right I Support
I am not going to say you are wrong either. I just replaced my mount and notice a difference. The old mount had worn out pretty bad and I could feel and hear the TC shift under load. Usually it was from a dead stop or a tight turn. I noticed it alot wheeling but 90% of the time it didn't shift and I had no complaints. This could be the low end torque of first and second gear of my manual trans. I never noticed it in any other gear but I don't wheel or take tight turns in any other gear either. Could just be that I have an old Heep; I mean Jeep.
So you have a good chance of not having problems but if you notice a drivline shake that is not caused by driveline stress you might think about the mount. |
#18 |
so i dont have to remove the four bolts if im droppin the tranny??? huh?
just undo the the six bolts add washers and bolt down or yes also remove the 4 tc bolts
NIGHT CREW #16 Yellow Jeep Club #67 My Build Thread- http://www.jeepforum.com/forum/f22/mitchin-02-tj-sport-973277/ THANK YOU TO 97tjeff, Metalcloak!!! |
#19 |
TITS
Of course you do. Those nuts hold the mount to the skid. If you're removing the skid, you need to support the bellhousing, remove the 4 nuts, then remove the 6 bolts holding the skid up.
#20 |
[QUOTE=MitchintheTrail;8859818]so i dont have to remove the four bolts if im droppin the tranny??? huh?
Sorry. You should if working on the tranny. I mixed it up when the one person posted about dropping the skid plate. |
#21 |
haha ok thanks guys
#22 |
if the nut stripped like that you had the wrong size socket
now the easy way to get it off would get a pair of vice grips, clamp them on the nut as hard as you can and turn until the stud snaps, it really dont take that much force to snap the tranny mount stud. then just run the other 3 when you put it back together
Click here --> - Buy popular magazines at discounted price, help my daughter for school DIY jeep highline guide -> click here DIY highline guide Save up to 40% off at advance auto parts by buying online, pick up at store free! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
