Stripped Brake Caliper Bolt at the knuckle - JeepForum.com
post #1 of 20 Old 05-05-2008, 06:58 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
So apparently my problem of my unknown noise wasn't my hub but my caliper becoming loose.
So the upper bolt hole on the passenger side front is stripped out.
I have two options as I see it:
1. Weld the hole shut and then re tap the hole with an 8mm x 1.25 tap and bit
2. get a new knuckle and Ball Joints.
I was thinking of trying the first one, but was wondering how it would actually work. I was only going to weld one side of the hole about half way in so that I can get a good strait hole. I'm not worried about the tap and bit because we have them at work that I can use.
If I go with the second, What knuckle will work with the 03+ TJ's. Would the cherokee dana 30s bolt up? IF so that would be great since there are several at a local pull apart.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 20 Old 05-05-2008, 07:06 PM
ThUmPeRcOn
Bump for a good guy in need of help! Wish I could help ya brotha weld/tapping it should be an option but how long will it hold? I have seen your wheeling videos
The original point and click interface was a Smith & Wesson.
ThUmPeRcOn is offline
post #3 of 20 Old 05-05-2008, 07:07 PM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
There is a third option...
http://www.jeepforum.com/forum/f9/mrblaine-s-knuckle-kit-547471/
We save dogs:
JBWood05TJ is offline
post #4 of 20 Old 05-05-2008, 07:13 PM
Stu Olson
Stu Olson's Avatar
You beat me to it.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #5 of 20 Old 05-05-2008, 07:17 PM
ThUmPeRcOn
Originally Posted by JBWood05TJ View Post
Shoot yeah I forgot about that post as well then and I still could not find the thread. mrblaine
post #6 of 20 Old 05-05-2008, 07:21 PM
ThUmPeRcOn
P.s. Stu! You are appreciated!
post #7 of 20 Old 05-05-2008, 07:30 PM Thread Starter
JeepRocks86
That's exactly what I need. Where might I be able to get one and how much?
I don't mind welding but that looks very good and aren't the knuckles cast?
For Sale:
post #8 of 20 Old 05-05-2008, 07:31 PM
JBWood05TJ
JBWood05TJ's Avatar
Look at Post ^ in the thread I linked. There is a link to another thread, which has a link to the site where you can buy the kit.
We save dogs:
post #9 of 20 Old 05-05-2008, 08:21 PM Thread Starter
JeepRocks86
http://cgi.ebay.com/ebaymotors/Jeep-...ayphotohosting
For Sale:
post #10 of 20 Old 05-05-2008, 08:29 PM Thread Starter
JeepRocks86
Just ordered the full shank for 1/2 inch bit. JF to the rescue again... Saves me the time of welding, drilling and re tapping.
For Sale:
post #11 of 20 Old 05-10-2008, 10:55 AM Thread Starter
JeepRocks86
I drilled and tapped the passenger side. THe upper passenger side was the one that stripped.
The kit that i bought was very good. Very easy to drill and tap the cast knuckles. Now i'm just waiting for the lock tight to dry so that I can put it all back together.
For Sale:
post #12 of 20 Old 05-10-2008, 01:25 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Unfortunately you can't weld, tap and redrill. The high carbon content of the knuckle mixes with the weld and makes a substance just slightly softer than diamond.
I ruined a NEW WJ knuckle by welding up the tapered holes and trying to drill them to reverse the taper for higher steer.
I have ruined about 100 dollars worth of exotic drill bits trying to salvage a 90 dollar knuckle.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #13 of 20 Old 05-10-2008, 01:29 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The instructions should give you a way to put it back together if you need to drive it right away.
But, I had a heck of a time finding a threadlocker that would actually lock those inserts in place. They come with a dry lock patch on them and I had to return them to EZ-Lock to have it removed as it was about useless and failed to lock every single time.
I then tested several of the gel types in stick form and they weren't much better.
Then I went back to the old stand by and it works perfectly every time if your surfaces are clean. Thus the caution not to use cutting oils.
I am Savvy
mrblaine is offline
post #14 of 20 Old 05-10-2008, 02:22 PM Thread Starter
JeepRocks86
I looked around at mcmaster as well as grainger and I couldn't beat the price that I bought the product for.
I am very happy with the kit. Very good directions. This is a must for anyone who has stripped a bolt.
It's about 75 outside and I have no hurry to move the jeep right now. I will probably do the driver side this afternoon and put it all back together tomorrow.
For Sale:
post #15 of 20 Old 05-10-2008, 03:20 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That was the intent, but I was surprised at how much had to be bought to get decent prices on stuff. I had to buy in very large quantities to get enough of a discount to put the kit together below retail of the individual parts. As in 200 drill bits at a time, 1000 inserts, 500 ampules of loctite and a 1000 bolts.
I'm happy the instructions work. I spent a fair bit of time on them trying to get stuff clear.
Fair enough.
I am Savvy
mrblaine is offline
Caliper bolt stripped, how to get off? TheDragonfly TJ Wrangler Technical Forum 33 12-22-2009 07:52 AM
Knuckle threads for Caliper bolts STRIPPED sebastian22 YJ Wrangler Technical Forum 16 12-15-2008 07:24 AM
Bottom bolt on front brake caliper stripped athos76 TJ Wrangler Technical Forum 1 08-09-2008 04:41 PM
Steering Knuckle is stripped @ lower caliber bolt attachment hole Jeepin088 TJ Wrangler Technical Forum 4 08-05-2007 07:16 PM
Size of helicoil for caliper bolt/stripped knuckle repair? Alheim YJ Wrangler Technical Forum 8 05-23-2007 05:46 AM
