-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Stripped Brake Caliper Bolt at the knuckle (http://www.jeepforum.com/forum/f9/stripped-brake-caliper-bolt-knuckle-554770/)
JeepRocks86 05-05-2008 06:58 PM
So apparently my problem of my unknown noise wasn't my hub but my caliper becoming loose.
So the upper bolt hole on the passenger side front is stripped out.
I have two options as I see it:
1. Weld the hole shut and then re tap the hole with an 8mm x 1.25 tap and bit
2. get a new knuckle and Ball Joints.
I was thinking of trying the first one, but was wondering how it would actually work. I was only going to weld one side of the hole about half way in so that I can get a good strait hole. I'm not worried about the tap and bit because we have them at work that I can use.
If I go with the second, What knuckle will work with the 03+ TJ's. Would the cherokee dana 30s bolt up? IF so that would be great since there are several at a local pull apart.
ThUmPeRcOn 05-05-2008 07:06 PM
Bump for a good guy in need of help! Wish I could help ya brotha:help: weld/tapping it should be an option but how long will it hold? I have seen your wheeling videos:D
JBWood05TJ 05-05-2008 07:07 PM
There is a third option...
http://www.jeepforum.com/forum/f9/mrblaine-s-knuckle-kit-547471/
Stu Olson 05-05-2008 07:13 PM
You beat me to it. :)
ThUmPeRcOn 05-05-2008 07:17 PM
Originally Posted by JBWood05TJ (Post 5179672)
Shoot yeah I forgot about that post as well then :idea: and I still could not find the thread. :) mrblaine :)
ThUmPeRcOn 05-05-2008 07:21 PM
P.s. :wave:Stu! You are appreciated!
JeepRocks86 05-05-2008 07:30 PM
That's exactly what I need. Where might I be able to get one and how much?
I don't mind welding but that looks very good and aren't the knuckles cast?
JBWood05TJ 05-05-2008 07:31 PM
Look at Post ^ in the thread I linked. There is a link to another thread, which has a link to the site where you can buy the kit.
JeepRocks86 05-05-2008 08:21 PM
http://cgi.ebay.com/ebaymotors/Jeep-...ayphotohosting
JeepRocks86 05-05-2008 08:29 PM
Just ordered the full shank for 1/2 inch bit. JF to the rescue again... Saves me the time of welding, drilling and re tapping.
JeepRocks86 05-10-2008 10:55 AM
I drilled and tapped the passenger side. THe upper passenger side was the one that stripped.
The kit that i bought was very good. Very easy to drill and tap the cast knuckles. Now i'm just waiting for the lock tight to dry so that I can put it all back together.
mrblaine 05-10-2008 01:25 PM
Unfortunately you can't weld, tap and redrill. The high carbon content of the knuckle mixes with the weld and makes a substance just slightly softer than diamond.
I ruined a NEW WJ knuckle by welding up the tapered holes and trying to drill them to reverse the taper for higher steer.
I have ruined about 100 dollars worth of exotic drill bits trying to salvage a 90 dollar knuckle. :rofl:
mrblaine 05-10-2008 01:29 PM
The instructions should give you a way to put it back together if you need to drive it right away.
But, I had a heck of a time finding a threadlocker that would actually lock those inserts in place. They come with a dry lock patch on them and I had to return them to EZ-Lock to have it removed as it was about useless and failed to lock every single time.
I then tested several of the gel types in stick form and they weren't much better.
Then I went back to the old stand by and it works perfectly every time if your surfaces are clean. Thus the caution not to use cutting oils. ;)
JeepRocks86 05-10-2008 02:22 PM
I looked around at mcmaster as well as grainger and I couldn't beat the price that I bought the product for.
I am very happy with the kit. Very good directions. This is a must for anyone who has stripped a bolt.
It's about 75 outside and I have no hurry to move the jeep right now. I will probably do the driver side this afternoon and put it all back together tomorrow.
mrblaine 05-10-2008 03:20 PM
That was the intent, but I was surprised at how much had to be bought to get decent prices on stuff. I had to buy in very large quantities to get enough of a discount to put the kit together below retail of the individual parts. As in 200 drill bits at a time, 1000 inserts, 500 ampules of loctite and a 1000 bolts.
I'm happy the instructions work. I spent a fair bit of time on them trying to get stuff clear.
Fair enough.
The time now is 02:55 PM.
