Quantcast Strange water leak coming from under the dash on the driver's side - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Strange water leak coming from under the dash on the driver's side
Old 10-11-2004, 03:36 PM   #1
Ludoc
Not sure where it's coming from so looking for ideas. I have an 04 TJ. I'll probably end up just taking it to the dealership but if it is something simple I will fix it myself to avoid the long wait. I was guessing from around the windshield wipers on the outside. There seems to be a hole on each one, but it is supposed to be there cause I looked at a few and they all have the same space. I was also thinking of a vent plate that is located right up around the hood / windshield on the outside, but I am not too sure what that goes to. The water only leaks when it is stationary and it rains. No water gets in while driving so that sorta rules out anything on the firewall I am guessing. Any suggestions?
[size=+1][color=red][b][FONT=times new roman][u]RED 04' TJ - 2.4[/FONT][/b][/color][/size][/u] [color=black][b][font=times new roman]4 In Lift, 31" Courser M/Ts, 4.56 gears, JKS Discos, Aussie Auto Locker[/font][/color][/b]
Just a basic Jeep... nothing special.
Ludoc is offline   Reply With Quote
Old 10-11-2004, 04:42 PM   #2
TJchick
Our '04 does the same thing, but only when there are heavy rains. I've come to just expect it from Jeeps since our XJ does the same thing, but it does bug me considering it's brand new. Ours is coming from right above the gas pedal. It just likes to pee all over my foot.
Good luck with the dealer. Let us know if you get any tips or fixes.
Our DD/Trail Toy:
'04 TJ X, Khaki w/ Khaki Hard Top
4.0L, 5spd (NV3550), 231
D30/35, 3.73s, 2"BB, 31" BFG ATKO
Husband's Trail Rig:
'97 XJ, 2 DR SE, Dark Green
4.0L, 5spd (AX15), 231
6", 33" MTRs, D30 (truetrac), C8.25 (No Slip), 4.10s
www.JeepOnly.com
TJchick is offline   Reply With Quote
Old 10-11-2004, 05:15 PM   #3
Jeepxj96
We have had some 04's come into our dealer having the same problem. The 2 that had the problem you are complaining about they both had water coming in from the back of the hood. Right where the rubber molding is to make a "tight" seal between the hood and the cowl. Underneith that rubber seal is a pinch weld, we take RTV and seal them up that way.
Go sit in your jeep while somone sprays a hose at that pinchweld (without the rubber on it, and the hood up) have them spray the whole pinch weld all that way across the Jeep. if you get a leak inside then you need to put some sort of RTV or silicone along that whole pinch weld.
Bob
1996 Land Rover Discovery with a bunch of stuff on super swampers
Jeepxj96 is offline   Reply With Quote
Old 10-11-2004, 07:08 PM   #4
Ludoc
I'll give that a try tommorrow and let you know how it turns out.
Old 10-12-2004, 04:16 PM   #5
TJchick
Thanks! I'll take a look at it too.
One question though...is the pinch weld not welded across or is it just a spot weld along the seam?
Our DD/Trail Toy:
www.JeepOnly.com
Old 10-12-2004, 06:34 PM   #6
RockPaws
Their is a TSB (Technical Service Bulletin) that came out some years ago 97 or 98 that talks about the water leak problem. You would have thought they would have fixed it by now. The dealer may be able to provide you with it. Or if its under warrenty just have them do it. As stated, they just add silicone to the leaky area, sort of like a band-aid to me.
[FONT=Trebuchet MS]01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
[URL=http://www.redrock4x4.com][COLOR=Blue]www.redrock4x4.com Rocks![/COLOR][/URL]
[URL=www.needhim.org/][COLOR=Blue]Need Him?[/COLOR][/URL][/FONT]
RockPaws is offline   Reply With Quote
Old 10-12-2004, 06:36 PM   #7
Jeepxj96
I cant remember...but I think it is just pinch welded along the whole seam.
Bob
Old 10-12-2004, 10:01 PM   #8
Ludoc
for some odd reason i cannot duplicate the leak... im at a loss for words lol
Old 10-13-2004, 08:16 AM   #9
brandongrover
I have a 04 TJ, mine P's on me as well. I just live with it and tell myself "its a jeep thing"
Black Jeep Member #333
2004 Sport
3.5" BDS w/ 1"MORE MML and 1" BL
Looks like a beast drives like crap, working on it...
Running Big Waylon's Old Gear Member #1
brandongrover is offline   Reply With Quote
Glock Forum
