Strange "Ringing" coming from my passenger floorboard!
#1 | |
My TJ has developed a new and even more annoying sound than its other 5 squeeks, rattles, and creaks.
It sounds like a thin piece of tin or other flimsy metal vibrating or "ringing" at various times such as at a certain RPM (vib from the engine) or when I hit a bump just right. It is coming form the passenger floorboard area or possibly lower dash. I suspected it was the speaker but I made sure those screws were tight. I suspected it was the jack parts next to the seat, but thats not it. ...and no, its not stuff in my glove box rattling around!
#2 |
check your exhaust pipe...may be coming loose. Also check y\to make sure your passenger seat bolts didn't come loose somehow.
#3 |
Hmmm didnt think about the exhaust. I just had a glasspack installed and figured if there was a problem, the guy would have pointed it out to make an extra buck.
It sounds like it is inside the cab and I think anything under the floor would be muffled a little...this is a very distinct inside sound. |
#4 |
turn the radio up thats what I do lol. I have the same thing kind of sounds its in the dash or something, like a pin swinging or something. Just another one of the many sounds of jeep.
#5 |
Check all bolts/screws that have washers on them.
My freightliner had a bolt in sleeper area that backed off just enough for the washer to move and it sounded like one of those bells people put on a cat. That will drive you crazy listening to that for 10 hours at a time. |
#6 |
i have the same sound in mine. i was hopin i could find out what it was on here. guess no luck
#7 |
Check the heat shield under the floor board, it might have come loose
#8 |
I get a squeek from the bar that braces the windshield up top. held on with two T30 Torxs. For a long time i thought it was from behind the dash.
#9 |
I figured it out. It was one of the springs under the seat. At some point it starts vibrating and "ringing".
I just took it off. I hope it wasn't important. There is one opposite of it across the seat, so I hope that is enough. If not, I will wrap it in electrical tape! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
