Strange Fan-like noise while driving - JeepForum.com
post #1 of 4 Old 02-06-2014, 03:02 PM Thread Starter
jaspercomp
Hello All,
I have a 2004 Jeep Rubicon, 4.0. I have this really strange noise that only happens when I'm driving down the road. It sounds almost like a fan hitting something or something is being hit - not a heavy knocking sound or anything like that. The noise only happens when I'm driving, not at idle, or when I race the engine, engage/disengage the clutch, it's not the heater/ac fan - what else is rotating only while moving?? oh and it's not the brakes, tried to find a correlation between that too, but no luck. Thanks in advance for any advice/suggestions! ps: it could also be described as a fast "clicking sound" but again, it stops when the jeep stops.
jaspercomp is offline
post #2 of 4 Old 02-06-2014, 08:07 PM
mukluk
What rotates only when the Jeep is moving? The driveshafts and axles. You can try driving the Jeep with only the front or rear driveshaft installed to narrow down where the ticking is coming from.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 4 Old 02-06-2014, 10:18 PM
JPNinPA
^^2x or crawl under and look for slop in the u joints by rocking the shafts or axels back and forth. There should be no slop at the u joint.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #4 of 4 Old 02-07-2014, 06:38 AM
Jwolfer
One of your U joints is bad in the front drive shaft. I had the same issue. It could be something else but I'd start there.
Jwolfer is offline
