Stranded Hope someone can respond fast. - JeepForum.com
post #1 of 31 Old 06-21-2013, 10:16 AM Thread Starter
RootJ
2000 Sport Manual
I was going about 55mph and tranny stopped pushing all gears. I pulled over and turned off the engine, waited a sec and started.
All 5 gears and reverse now engage but act as if in 4low.
I removed the front drive shaft entirety at front axle and at t-case.
Behavior did not change. All gears work shift properly but rpms go up so that 30mph gives me 2000 rpm in 5th gear.
RootJ is offline
post #2 of 31 Old 06-21-2013, 10:18 AM
NotURMailman
Did you check to see what position the transfer case linkage on the side of the case was in?
Almost sounds like the linkage broke and it went into neutral and then low.
Not sure how that would be possible, but... ?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 31 Old 06-21-2013, 10:23 AM
Ben
I agree with the Mailman. Did you maybe run over something that kicked up and hit your transfer case linkage?
Is your transfer case hot to the touch? I don't know why/how but if the shifter fork tongs somehow broke maybe it's slipped into low somehow?
Ben is offline
post #4 of 31 Old 06-21-2013, 10:25 AM Thread Starter
RootJ
Would that matter if the front drive shaft is removed?
RootJ is offline
post #5 of 31 Old 06-21-2013, 10:39 AM
Netrix
Yes, they're both connected to the same transfer case.
Netrix is offline
post #6 of 31 Old 06-21-2013, 10:42 AM Thread Starter
RootJ
Aha
RootJ is offline
post #7 of 31 Old 06-21-2013, 10:48 AM
Necko2529
If its in 4lo for whatever reason its going to drive slow regardless which driveshaft you remove.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #8 of 31 Old 06-21-2013, 10:53 AM
sjones26573
If he removes both, it wouldn't drive at all.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #9 of 31 Old 06-21-2013, 10:56 AM Thread Starter
RootJ
Ha ha ha ha. Yeah no shaft at all them nothing will turn.
RootJ is offline
post #10 of 31 Old 06-21-2013, 11:01 AM
Necko2529
No ****! Try it on a downhill slope...
post #11 of 31 Old 06-21-2013, 11:02 AM
Necko2529
OP, have you figured anything out?
post #12 of 31 Old 06-21-2013, 11:03 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
T case linkage or clutch going out.
TheBoogieman is offline
post #13 of 31 Old 06-21-2013, 11:06 AM Thread Starter
RootJ
Ok, so the linkage moves on the outside of it but still not shifting out of 4 low
RootJ is offline
post #14 of 31 Old 06-21-2013, 11:07 AM Thread Starter
RootJ
And boss bugging me to come to work tonight. Ha!
RootJ is offline
post #15 of 31 Old 06-21-2013, 11:07 AM
Necko2529
Pull it by hand at the tcase. Pull it forward.
