STP fuel products good or bad - JeepForum.com
post #1 of 6 Old 08-19-2010, 01:21 PM Thread Starter
LiveAndLearn
need opinion on these. been using them for a little while.
LiveAndLearn is offline
post #2 of 6 Old 08-19-2010, 01:27 PM
happymudder10
They foul up your plugs pretty fast
Just a traveling cat in a tall black hat riding a goat. Nothing to see here.
happymudder10 is offline
post #3 of 6 Old 08-19-2010, 01:35 PM
mdm
Farm Wheeler
The only fuel additive that I believe is worth while are products like Heet that keep with water in the fuel from condensation during extreme cold weather. The only thing the rest of them to is reduce your fuel consumption by removing weight from you wallet.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 6 Old 08-19-2010, 01:45 PM
kehoe
For kicks, I use the injector cleaner once or twice a year. I have recently begun monitoring my mpg's at every fill-up, and I can tell you that I did not see any real benefit in mileage after using the injector cleaner last time.
kehoe is offline
post #5 of 6 Old 08-19-2010, 03:06 PM Thread Starter
LiveAndLearn
thank you. in the trash it goes.
post #6 of 6 Old 08-19-2010, 04:00 PM
bottomdrifter
I did the 2 part fuel injection system cleaner for 20.00 at wally world. I noticed a difference in acceleration after running through the fuel additive. 1st part is a liquid that is put through a vacuum source the second part fuel additive. It is a gumout system. Mine is a 2006 4.0 and had 56k when I did it. Really worth the 20.00 imo.
bottomdrifter is offline
stp , fuel
are fuel injection kits any good ??? metalroses YJ Wrangler Technical Forum 19 12-17-2009 12:02 AM
Good spark and fuel pressure won't run. jeepman95yj YJ Wrangler Technical Forum 2 11-30-2009 04:44 PM
Good Deals on Products gredden Wrangler General Discussion 2 10-08-2008 08:24 AM
Need Help with Good Cleaning Products Please! GA TJ TJ Wrangler Technical Forum 6 09-12-2005 03:20 PM
OBA installation problems and, what products work good to air down and then air tires BudmanV6 YJ Wrangler Technical Forum 2 06-03-2005 07:39 AM
