Stolen PCM/ECM - What PN do I buy? - JeepForum.com
post #1 of 17 Old 07-06-2010, 05:51 PM Thread Starter
MarineOrdO
Jeepers,
New here so hope I did this right.
Scored an abandoned 00 Sport 4.0L A/T a few weeks ago - need to replace the computer, but have no idea which one was originally in it. Are the similar PN's the same or different for 2.5L/4.0L, MT/AT, Standard emission/Low emission, etc.
Also curious if it's just a plug and play (used from junk yard work?) or do I need to get it flashed to the VIN/mileage?
Prices range from $200 for a rebuild/flashed/warranty version to $50 or less on Ebay for some used versions.
Any advice appreciated.
MarineOrdO is offline
post #2 of 17 Old 07-06-2010, 07:29 PM
Mousejockey
Id say go with the $50 one, if it fails you would probably have to pay at least that for the core on the rebuilt one.
But Id stick with the same yr, trans, engine on the used/rebuilt one
Mousejockey is offline
post #3 of 17 Old 07-06-2010, 08:15 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Does the engine exhaust have the 2 mini cats on the "Y" pipe?...
Knuckelhead is offline
post #4 of 17 Old 07-08-2010, 02:01 PM Thread Starter
MarineOrdO
Mousejockey - you're right. I called one of the ECM replacement companies and they are charging me an extra $49.99 if I don't have the core to send them.
Knucklehead - no mini cats on the Y pipe coming down from the exhaust manifold. It was registered in Utah last if that has anything to do with the Standard Emission/Low Emission issue. I'm guessing the mini cats are for states like CA and such.
post #5 of 17 Old 07-08-2010, 03:05 PM
Knuckelhead
AFSOC Retired
You don't have an ECM, you have a Powertrain Control Modual (PCM) and the one you buy will have to fit the non mini cat configuration for that specific year 2000 4.0L...
post #6 of 17 Old 07-08-2010, 07:31 PM Thread Starter
MarineOrdO
Semantics - got it. Thanks.
post #7 of 17 Old 07-08-2010, 07:58 PM
masterwacker
Actually not semantics. An ECU only controls the engine whereas a PCM controls engine and tranny. I thought the same thing until I was schooled on it too. Did you get a good deal on the TJ?
masterwacker is offline
post #8 of 17 Old 07-10-2010, 01:23 PM Thread Starter
MarineOrdO
Seems to me that PCM, ECM and ECU are somewhat interchangeable acronyms when discussing the computer. There are companies out there that refer to the PCM (now that I know) as an ECM and ECU and if you only Google PCM you are not going to get all the information.
The 00 has got a 6" Skyjacker Long Arm Lift, 35x12.50 BFG MT's and the tub is Rhino lined. Solid body, no big dents, good paint, etc. Had to research who had the lien on the vehicle, but once I found it I contacted them and picked it up for $2K as the previous owner had defaulted and they were just glad to get something out of it and not have to deal with the recovery. Took a few phone calls and such, but it was worth it.
The cheap PCM's on Ebay seem to have disappeared so I guess I'll be going with a reman one with a warranty for the $200-$250 range.
post #9 of 17 Old 07-10-2010, 01:26 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The only junkyard PCM you can use would be one from the same model year TJ, engine, and transmission as yours. If you go onto eBay or maybe Amazone.com now too, you can find remanufactured PCM sellers that will program one to work on your Jeep based on nothing more than your VIN#.
Gone on vacation until August 25.
Jerry Bransford is offline
post #10 of 17 Old 07-10-2010, 01:30 PM Thread Starter
MarineOrdO
Thanks - I guess that answers it then. If its the same year, engine, trans. then its a plug and play without VIN programming. If not, then a reman with VIN programming is the answer.
Appreciate the assist gents.
post #11 of 17 Old 07-10-2010, 03:35 PM
Knuckelhead
AFSOC Retired
Some 2000 4.0L TJ's have the mini cats, some do not. The PCM has to match that setup also...
post #12 of 17 Old 07-10-2010, 07:19 PM Thread Starter
MarineOrdO
OK, I looked up that mini cat deal and saw the bulbed cats at the top of the Y pipe under the manifold. Mine definitely do not have those. A couple other entries mentioned that those Jeeps were Low Emission - CA types.
I found this PCM on Ebay - it says "Standard Emission (Federal)". I'm guessing that is the one without the mini cats. Is that a correct assumption?
00 JEEP WRANGLER ENGINE ECM: eBay Motors (item 110516122285 end time Aug-03-10 13:38:27 PDT)
post #13 of 17 Old 07-10-2010, 07:28 PM
Knuckelhead
AFSOC Retired
You need to get the part numer from that PCM and match it with what DC sells...
post #14 of 17 Old 07-10-2010, 07:57 PM Thread Starter
MarineOrdO
Got it - thanks. Hopefully this Ebay seller will give up the info. If not, I'll hit the dealership to make some friends.
post #15 of 17 Old 07-10-2010, 08:09 PM
Knuckelhead
AFSOC Retired
Your welcome and post back as to what you find...
computer , ecm , ecu , electrical , pcm , TJ
Gas Cap Stolen gtospeeding TJ Wrangler Technical Forum 40 12-20-2007 01:05 PM
*Need Help* Keep from being stolen twinjeep97 TJ Wrangler Technical Forum 60 09-01-2006 07:37 PM
YJ stolen...looking for a TJ skimmer TJ Wrangler Technical Forum 10 07-18-2006 12:20 PM
Stolen key Anachron474 TJ Wrangler Technical Forum 9 09-15-2004 10:42 AM
Almost got stolen Francois YJ Wrangler Technical Forum 15 06-23-2004 10:27 PM
