stock track bar bushing - JeepForum.com
post #1 of 5 Old 09-03-2012, 08:43 PM Thread Starter
noise_maker
How much should the bushing in the stock track bar compress while turning 10-2 or lock to lock?
more info.....
Helping my neighbor with a DW issue in a 2006 with 45k on the clock, 3" lift (+BL with allot of trimming) on 35s".
The wobble happens at ~40-45 mph and drops off at 50. At any speed 30-60 if you hit a hard hole or drop a tire off on the shoulder it comes back for several seconds.
All the TREs and ball joints have no play and has a new steering stabilizer (Rancho). The tires are balanced and don't shake when put on a different jeep in the same position. I can't wiggle the unit bearings and they are not noisy on the road. The toe is 1/8".
However I can get the bushing in the track bar to compress a little so I am thinking that may be my issue.
At full lock its maybe 1/4-3/8"
Going back and forth 10-2 I can it compress maybe 1/16"-1/8"
Not sure what it normal with 35s. I pulled it and the bushing "looks ok" in terms of it not being overly cracked or dry-rotted and the TRE is fine.
Thansk
noise_maker is offline
post #2 of 5 Old 09-04-2012, 06:45 AM
Jeepsr4me
If its moving at all its not good for DW. I just verified my new TB had zero movement where the old one moved over 1/8 inch.
Jeepsr4me is offline
post #3 of 5 Old 09-04-2012, 06:49 AM
Imped
Imped's Avatar
You want zero movement. If you have any movement, you don't have a solid connection and therefore, may have found a culprit to your wobbles.
OlllllllO
IndyORV
Imped is offline
post #4 of 5 Old 09-04-2012, 07:03 AM Thread Starter
noise_maker
Thanks guys. So if you have someone go lock to lock while you look at the bushing, it shouldnt compress at all, even when held At full lock?
I just want to make sure before I throw parts at it. On my own jeep, which has no dw, I can get the bushing to compress a little at full lock.
post #5 of 5 Old 09-04-2012, 08:49 AM
HAYSHAKER170
I wondered the same thing as well. It seems to me unless it is a heim joint, it will always compress a little. Right?
HAYSHAKER170 is offline
bushing , tj , track bar , trackbar
Bushing kit or new track bar? Dani5h87 TJ Wrangler Technical Forum 8 06-21-2012 06:30 PM
Track bar bushing... Wtf! TheDodson TJ Wrangler Technical Forum 7 04-05-2011 11:43 PM
track bar bushing roachy20 TJ Wrangler Technical Forum 1 12-13-2007 10:33 PM
Bad Track bar bushing bradb511 TJ Wrangler Technical Forum 4 06-14-2006 03:22 PM
Removing stock track arm bushing NJswampman TJ Wrangler Technical Forum 1 05-30-2003 07:09 AM
