Stock tow hook bolt size and length - JeepForum.com
 10Likes
post #1 of 18 Old 09-22-2017, 12:35 AM Thread Starter
Guy_Van_Horn
I'm looking into putting some OEM tow hooks on the front of my `99 TJ. I've figured that they are T55 torx button head, but I'm not sure if they are 1/2"-13X2.00" or M12X60mm. The ones I have on right now are ~35mm long without the hooks, so that leads me to believe they are M12X60mm. Can anyone verify this?
Thanks.
Sent from my SM-G920V using Tapatalk
Guy_Van_Horn is offline
post #2 of 18 Old 09-22-2017, 02:07 AM
mukluk
Not having any luck finding the specs listed for the bolts, but they're part number 06036060AA or 6036060AA if that helps... looks like there are a decent number of places that still have them for sale online.
Guy_Van_Horn likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 18 Old 09-22-2017, 04:36 AM
Jeepsr4me
Just take one of the short ones out and take to home depot or any fastener place,. I would NOT get a Torx head,.. Get a regular bolt... way easier to find a socket to get the bolt in and out later., Less likely to strip out.... Or require a expensive tool to remove..
Jeepsr4me is offline
post #4 of 18 Old 09-22-2017, 07:15 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Guy_Van_Horn View Post
I'm looking into putting some OEM tow hooks on the front of my `99 TJ. I've figured that they are T55 torx button head, but I'm not sure if they are 1/2"-13X2.00" or 12mmX60mm. The ones I have on right now are ~35mm long without the hooks, so that leads me to believe they are M12X60mm. Can anyone verify this?
Thanks.
The weld nuts in the frame for the front tow hooks are 1/2-13 thread. Bolt length should be determined by adding the thickness of the tow hook and another inch of length to fully engage the weld nut's threads taking into account the washer under the head if used, the thickness of the bumper etc. Don't overestimate and get a bolt with a shank that has enough unthreaded section that it bottoms out on the weld nut threads before it gets tight.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 18 Old 09-22-2017, 07:54 AM
NotURMailman
NotURMailman's Avatar
Are all TJs 1/2" thread on those bolts, or did the late models change to metric?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #6 of 18 Old 09-22-2017, 08:43 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
They're all 1/2x13. Use Grade 8 strength.
Jerry Bransford is online now
post #7 of 18 Old 09-22-2017, 10:22 AM Thread Starter
Guy_Van_Horn
Thank guys. I just ended up buying a pair of OEM tow hooks off ebay that had the bolts included, so I'll measure them and report back here when they arrive.
post #8 of 18 Old 09-26-2017, 12:58 PM Thread Starter
Guy_Van_Horn
So they're ~2.5" long, and they are SAE grade 5, in case anyone wants to know.
post #9 of 18 Old 09-26-2017, 01:10 PM
Jerry Bransford
Administrator
Grade 5 in that position has been known to bend in some harder pulls, that's why I recommended Grade 8 above.
post #10 of 18 Old 09-26-2017, 01:27 PM Thread Starter
Guy_Van_Horn
I don't doubt you, I'm just reporting what the OEM bolts are. Thank you.
post #11 of 18 Old 09-26-2017, 02:44 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
They are the Torx large pan head, correct?
I am Savvy
mrblaine is offline
post #12 of 18 Old 09-26-2017, 02:57 PM Thread Starter
Guy_Van_Horn
Yes, T55 torx drive, and 1/2-13UNC thread size like Jerry said previously.
post #13 of 18 Old 09-26-2017, 03:33 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I had the chart at one time that showed what the markings on those bolts meant. Did you find one that showed how to tell they are grade 5?
I am Savvy
mrblaine is offline
post #14 of 18 Old 09-26-2017, 04:28 PM Thread Starter
Guy_Van_Horn
Well, not as definitively as I would have liked, but it's probably correct. The shorter ~1.5" long bolts have three equally spaced radial hash marks. That is clearly SAE grade 5. The longer ~2.5" bolts used with the tow hooks have 4 dots right next to each other. I spoke to a guy at Fastenal, and he tells me that they looked those markings up before, and confirmed they also mean SAE grade 5. I wish I had a copy of SAE J429, because it probably identifies the dots as an acceptable alternative marking for grade 5. I'll keep looking.
Edit: so I did find at least an excerpt from SAE J429-2011, and it does show the radial hash head markings that I'm sure we're all familiar with. However the four dot marks are not there. At least in the excerpted pages I found. I'm wondering if since these are button head, torx drive bolts, if they are controlled by a different SAE standard. I already looked in ASTM F835, and it's not defined there.
post #15 of 18 Old 09-26-2017, 04:45 PM
Ravenbar
Number of Hashes +2 = SAE bolt grade.
I find nothing on bolts marked with dots.
Got a picture of the head?
Knuckelhead and Guy_Van_Horn like this.
Project Thumper:
Ravenbar is offline
