Stock TJ Track Bar Removal? - JeepForum.com
post #1 of 8 Old 10-06-2013, 12:30 PM Thread Starter
jcott948
I am wondering if its okay to run my stock TJ (daily driver) without a rear and/or front track bar?
All I can find information on is for lift kit installation and heavy off-road use.
Any and all thoughts are much appreciated!
jcott948 is offline
post #2 of 8 Old 10-06-2013, 12:32 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
nope, you need them both.
the track bars are the only thing keeping your axles fixed laterally under the vehicle. also in front with no track bar you'll have no steering.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 8 Old 10-06-2013, 12:36 PM
ItsMrHall
No!! do not remove either track bar with stock suspension design!
2006 TJ 2.5" OME - 1.25" JKS BL
35" Mt/R
Dana 44's // Lockers and stuff
"No its a tie. That guy doesn't count, he can't even read!"
ItsMrHall is offline
post #4 of 8 Old 10-06-2013, 01:35 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X3, the last thing you want to remove on a TJ would be its track bars. It'd be bad enough to remove the rear, but removing the front track bar would mean you couldn't steer... the steering would instead move the axle side to side if the track bar wasn't there to prevent that from happening.
And for the same reason the track bar is required, because of the TJ's coil spring suspension, it's not a good idea to remove the antiswaybars either.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #5 of 8 Old 10-06-2013, 02:01 PM
BYuen
BYuen's Avatar
Yup, you'll need both track bars with a TJ's coil spring suspension. The YJ guys can remove their track bars because of the leaf spring suspension, which is able to stabilize the axle under the Jeep without them.
BYuen is offline
post #6 of 8 Old 10-06-2013, 03:12 PM
gebirgziege
Maybe he meant sway bars...
Did you mean sway bars????
"track bars" must have been a typo/mistake...
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #7 of 8 Old 10-06-2013, 04:25 PM
Unlimited04
you don't want to remove those either
Useful Write-Ups:
Funny:
post #8 of 8 Old 10-07-2013, 07:15 AM Thread Starter
jcott948
Thanks everyone. I went back and noticed the info I was reading previously was for YJ's (leaf springs)...makes a lot more sense now.
jcott948 is offline
