Stock rotor thickness - JeepForum.com
post #1 of 12 Old 01-01-2008, 06:44 PM Thread Starter
Barroom Hero
Does anyone know the stock rotor thickness on a 2001 TJ? Changed my pads and rotors today and the rotors are too thick, which end up not letting the wheels turn once their bolted on. Got my rotors from NAPA, going back tomorrow, but I would like to know what to look for.
Thanks,
Keith
2001 TJ Mods: Umm, Herculiner?
1995 Camaro Z/28. Intake, Aluminum intake elbow, LT headers, 3.73's, plenty of other goodies.
Barroom Hero is offline
post #2 of 12 Old 01-01-2008, 07:09 PM
flatlander757
They changed how deep the rotors are in like 2002 or so IIRC. You need the earlier kind where the hat should measure 2-1/8", you got the ones that are 2-1/4". I ran into the same thing today at work on a Cherokee.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #3 of 12 Old 01-01-2008, 08:00 PM Thread Starter
Barroom Hero
Thanks, amazing the difference 1/8" makes. Looks like I'll be bringing my ruler to NAPA tomorrow.
post #4 of 12 Old 01-01-2008, 08:02 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Better yet, take in one of your old rotors to make sure the new rotor's dimensions match.
Jerry Bransford is offline
post #5 of 12 Old 01-01-2008, 08:05 PM
Nonya
there are two different rotors,2.75 inch and 3 inch.Ask me how i know?I ran into the same thing you did.If your jeep came with composite rotors you need 3 inch.
Nonya is offline
post #6 of 12 Old 01-01-2008, 08:24 PM Thread Starter
Barroom Hero
Not sure what kind mine came with, any way to tell? I would take the rotors with me to the store, but I had to put them back on so I could drive the car.
post #7 of 12 Old 01-01-2008, 08:28 PM
Nonya
Just measure the total thickness from outside to outside.Lay it flat on a surface and lay a straight edge across the lug flange then measure down to the surface.
Nonya is offline
post #8 of 12 Old 01-01-2008, 08:35 PM Thread Starter
Barroom Hero
Thanks, will do
post #9 of 12 Old 01-01-2008, 08:49 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That won't work at a general rule if one rotor is composite and the other is full cast and both were made for the same years.
The important dimension is from the inside of the rotor hat to the inboard face of the rotor as it's mounted on the unitbearing.
The way you are having them measure will not take into account the difference in thickness of the cast versus drawn steel rotor hats.
In other words, you could wind up with a late composite and an early full cast and be nearly the same overall height.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #10 of 12 Old 01-01-2008, 08:55 PM Thread Starter
Barroom Hero
So in summation in need a shorter hat, correct?
post #11 of 12 Old 01-01-2008, 09:11 PM
Nonya
when i went to buy rotors they had two different ones....2.75 thick and 3.00.I needed the 3 inch,just measure them like i said...actually just get the other ones...you already tried the wrong ones
Nonya is offline
post #12 of 12 Old 01-01-2008, 09:17 PM Thread Starter
Barroom Hero
Good point
Frame thickness dankeenan YJ Wrangler Technical Forum 5 05-19-2008 08:28 AM
Rotor thickness??? Trudd TJ Wrangler Technical Forum 2 08-16-2007 05:14 PM
Thickness of Stock Plastic Windows swampass2 TJ Wrangler Technical Forum 4 02-20-2007 11:17 AM
1998 tj front disc rotor thickness? silver97tj TJ Wrangler Technical Forum 2 08-16-2006 10:26 PM
Minimum Rotor Thickness? FloridaJeeping TJ Wrangler Technical Forum 3 04-02-2005 06:37 PM
