Stock Rims - JeepForum.com
post #1 of 5 Old 09-27-2010, 12:00 PM Thread Starter
Vic99TJ
Stock Rims
Whats the max tire size on stock rems?
Vic99TJ is offline
post #2 of 5 Old 09-27-2010, 12:05 PM
wlmonk
Do you mean diameter, width, both? And lots of sizes may fit on the wheel but, if mounted on the Jeep, you may get some rubbing due to interference. And then there's the matter of whether or not the Jeep has been lifted in any way.
The largest size most people feel will work on an unlifted TJ with stock wheels driven mostly on the street is a 31X10.50.
wlmonk is offline
post #3 of 5 Old 09-27-2010, 12:41 PM
timberwolf0122
Without a spacer you can't fit anything over 10.5" wide, with regards to diameter you can fit what ever you have the lift for.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
post #4 of 5 Old 09-27-2010, 12:46 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
I've got 33x12.50's on my stock rims, but have to run spacers.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #5 of 5 Old 09-27-2010, 03:57 PM Thread Starter
Vic99TJ
I ment both width and diameter.
Vic99TJ is offline
Upgrade stock tires/rims with larger stock tires/rims (08 Wrangler Unlimited)QUESTION makstuss JK Wrangler Technical Forum 3 02-20-2011 04:23 PM
Stock rims on a 8.8? TJamz TJ Wrangler Technical Forum 9 10-22-2009 09:38 AM
What can I do with my stock rims? 4bangerWrangler TJ Wrangler Technical Forum 8 04-28-2008 06:45 AM
Biggest tires can put on stock 06 se w/stock rims? thebatmobile TJ Wrangler Technical Forum 4 04-29-2007 11:34 AM
stock rims girlzcan2 TJ Wrangler Technical Forum 1 04-03-2003 12:14 PM
