Quantcast stock radio illuminates but doesn't turn on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > stock radio illuminates but doesn't turn on
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 06-13-2009, 10:44 PM   #1
ksufalcon
Let me first say that this is my first jeep I've owned.
I installed a CB today and tied the power and ground into the the stock radio wiring harness and everything seemed to work just fine the CB came on and functioned correctly, however when I put the stock radio back in and got everything back together the radio wouldn't turn on. The CB works and I've check the fuse behind the glove compartment for the radio and it's good. If I turn on the lights the buttons all light up but I get nothing on the LCD screen and no sound, I also can't eject a CD that's in the Radio.
I'm hoping someone can give me some idea's to check.
Thanks
ksufalcon is offline   Reply With Quote
Old 06-13-2009, 10:55 PM   #2
Mean Max
Mean Max's Avatar
Check your owner's manual for a radio "security code" number. My '03 Durango & '06 MegaCab both had to be reset (I did it myself following the owner's manual instructions) after being disconnected from the power source.
Maybe yours is the same type of system?
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 06-13-2009, 11:58 PM   #3
2002StockTJ
Did you tap into the power via vampire or some other means? Maybe you tapped into the wrong wire and it's shorting the radio. Make sure you are using the +12 volts switched and not constant.
Just throwing out suggestions.
2002StockTJ is offline   Reply With Quote
Old 06-14-2009, 09:15 AM   #4
ksufalcon
I'm using the +12 volt switched and not the constant. The previous owner of the jeep must have had an aftermarket amp or something in the jeep because all of the speaker wires have been spliced into. There was a pigtail coming off of the +12v switched line that I used to connect to. I haven't had a single problem with the radio until this and have had it disconnected previously.
Old 06-14-2009, 11:38 AM   #5
ksufalcon
Found the problem, I didn't realize there was two radio fuses, one behind the glove compartment and one under the hood. Opened the fuse block under the hood to check on a different fuse and noticed a radio fuse there and it was blown replaced the fuse and everything works great. The fuse under the hood seems to feed the constant power since I had power to the switched +12.
Glock Forum
