Stock Jeep Wobbles at 50 MPH - JeepForum.com
post #1 of 15 Old 07-30-2010, 10:57 AM Thread Starter
MartinTravels
1989 XJ Cherokee
I have a 2006 Wrangler X. It has about 23K miles on it. It is a 6 speed transmission with the 4.0 engine, and the Jeep is completely stock. At 50 MPH, the jeep vibrates. It vibrates with or without the top down. It vibrates uphill, downhill and on flat road (I think it is worse downhill). It really wobbles when the transmission is in gear (it is worse when power is to the tires). When coasting at 50 MPH, it seems the vibration almost completely vanishes.
It is only for a very brief window at exactly 50 MPH that this wobble happens, but it is enough for concern. Any body else had this issue? Any ideas on a fix? Thanks in advance for all the suggestions.
MartinTravels is offline
post #2 of 15 Old 07-30-2010, 11:03 AM
KEH1997
Sounds like a wheel imbalance to me... Mine does the same thing, and that's what my problem is.
KEH1997 is offline
post #3 of 15 Old 07-30-2010, 11:07 AM
Piratejonh
Piratejonh's Avatar
Whats vibrating? The whole jeep or the steering wheel?
Have you done anything to the jeep prior to this symptom?
Ever go off road? Mud or rocks?
Your profile says totally stock. Maybe a wheel weight was knocked off. Look on the wheels edges for a clean spot. If you've been in the mud maybe its packed in your wheel throwing it off.
Vibrating under load but not while coasting might be a driveline problem.. Seems early for a U-joint to be going bad- unless you go off road. And on that note its unlikely you control arm bushings are going bad.
Jeep took another piece of my finger today...
Piratejonh is offline
post #4 of 15 Old 07-30-2010, 11:09 AM
McKBrew
JK Wrangler
From everything I have read, pretty much all wobbles related to certain speeds are a result of tire imbalance.
I've heard a couple different recommendations including balancing with airsoft BB's or Road Force balancing which is offered by some tire shops.
McKBrew is offline
post #5 of 15 Old 07-30-2010, 11:27 AM Thread Starter
MartinTravels
1989 XJ Cherokee
I have never taken it off road and have done nothing to it other than gas in the tank and removing the top and doors. I will check the wheels to see determine if a weight has fallen off... I just don't know.
post #6 of 15 Old 07-30-2010, 11:33 AM
tim87114
Martin, the important question from above, is does the steering wheel shake? Meaning do you feel the "vibration" in the steering wheel or do you mean you feel it in your foot or tub of the jeep?
Front end vibration on jeeps is common enough if you look at it as Death Wobble or DW as referred to here on the forum. It can happen to any jeep at any given mileage for different reasons.
I agree that tire balance is the first place to look. Beyond that, you would be standing in line with the rest of us guys running a stock jeep wondering what the heck is going on.
tim87114 is offline
post #7 of 15 Old 07-30-2010, 11:35 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Rotate and balance the tires.
TheBoogieman is offline
post #8 of 15 Old 07-30-2010, 11:37 AM
TheBoogieman
I would agree if he had 35's,but his little tires can be balanced right on any machine.
post #9 of 15 Old 07-30-2010, 11:48 AM Thread Starter
MartinTravels
1989 XJ Cherokee
Just to clarify, I feel it in the steering wheel. The steering wheel shakes back and forth. But the real oddity is that it does not shake while coasting. I would assume it it was a wheel balance issue the wobble would occur in neutral at 50 MPH as well as when in gear at 50 MPH.
post #10 of 15 Old 07-30-2010, 11:59 AM
spillz
Martin...Martin here
Martin.....
I had the exact same issues with my stock 2006 LJ with 29k miles on it. I took my LJ to a local tire shop had the tires balance and rotates. Problem solved.......wheel was out of balance....
spillz is offline
post #11 of 15 Old 07-30-2010, 12:25 PM
bobthetj03
So if you put the clutch in or throw it in neutral while at 50 mph the wobble vanishes? Is the wobble in the steering wheel or do you feel it in the seat?
Sorry, took too long to post. Questions answered. Sounds like tire balance to me. I have the same shimmy at 50 and I've went to 3 different shops and had all four balanced 3 times till the 3rd shop got it close. Still shimmys a little but is better.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #12 of 15 Old 07-30-2010, 06:39 PM Thread Starter
MartinTravels
1989 XJ Cherokee
I took the rig to the local Les Schwab here in Monroe, WA (BTW, I have received EXCELLENT customer service every time I go there). They quickly identified the problem as a missing weight on the right front tire. They balanced the tire, aired it up and checked the balance and air on the remaining three.
Twenty six dollars later the problem is solved! Thanks to all who posted on this thread... you were all right!
post #13 of 15 Old 07-30-2010, 10:29 PM
McKBrew
JK Wrangler
Right on. Glad that helped.
McKBrew is offline
post #14 of 15 Old 07-30-2010, 11:06 PM
imhere631
some times the balancing weights on the drive shaft can get thrown. Look to see if you have a spot that might indicate that the driveshaft is out of balance.
imhere631 is offline
post #15 of 15 Old 07-31-2010, 12:49 AM
SugarBear
1969 CJ5
1969 CJ5
2.5" Rancho Kit/Shocks/Steering Stabilizer, 2" Shackles, Koenig PTO Winch, 31x10.5x15 Cooper STT's
SugarBear is offline
dw , death wobble , stock , tj , wrangler
newbie jeep wobbles????? rip_1986 YJ Wrangler Technical Forum 21 08-21-2008 07:03 PM
used search, jeep still wobbles opee9981 TJ Wrangler Technical Forum 2 08-15-2007 01:08 AM
jeep wobbles? mr. pink TJ Wrangler Technical Forum 13 08-11-2007 08:37 AM
jeep wobbles at 60 mph, tire shop says my 33's are too big ???? chaznad TJ Wrangler Technical Forum 14 08-26-2005 04:58 AM
TJ Wobbles ghiradelli777 TJ Wrangler Technical Forum 13 01-25-2005 02:32 PM
