Stock jeep with 32 inch tires? - Page 2 - JeepForum.com
post #16 of 23 Old 07-31-2013, 09:20 PM
T-Mav
Here is mine stock. 4 in offset cragers and 31 kanati mud hogs. Love the tires by the way great traction and tough. 149$ for rubber and 60$ apiece for rims. Zero rubbing.
T-Mav is offline
post #17 of 23 Old 07-31-2013, 09:37 PM
LutzkaninTJ
I had 32's stock right before my lift. Don't do it. Bad idea
LutzkaninTJ is offline
post #18 of 23 Old 07-31-2013, 11:01 PM
CommonSense
Ya know what would be a cheap, bad a$$ set up? try a JKS 1.25" BL W/ 32" 11.5" r 15s W/ spydertraxx 1" wheel spacers, and a 1"MML to clear that oil pan and future mods... just sayin It'd b a pretty decent setup... anybody done this??? pics?
CommonSense is offline
post #19 of 23 Old 08-01-2013, 04:46 AM
Bigdude408
I was considering something along the lines of that. With a TT and gas tank lift and all the skids you can slap on. I wanted to add springs for flex though.
Bigdude408 is offline
post #20 of 23 Old 08-01-2013, 05:34 AM
lloydsmale
2015 JK Wrangler
31 10.50s bfg ats rub at full stearing travel on mine with a 2 inch buget lift and stock rims. I could have ajusted the stops but didnt want to give up the turning radious so i let them rub. It didnt hurt the tire any. I then just bought the right offset rims and its not a problem anymore. Bottom line is if you have a 4cyl and arent regearing you sure dont want to go any bigger then 31s. Mines doggy enough with them.
2015willys 4 cyl tj 2017 silverado yamaha grizzly, Polaris rzr 04 z06 vette, 600/800 crossfire cat
lloydsmale is offline
post #21 of 23 Old 08-01-2013, 09:49 AM
4banged
Keep in mind that the back spacing on the rims will have a lot to do with whether you get rubbing at full turn. I had 31's on mine with no lift and it was fine but I like it much better now with the 2" BB.
4banged is offline
post #22 of 23 Old 08-02-2013, 07:55 PM
Bigdude408
I have 32's on my 4 banger, while it is a turd, it was with stock size as well. I don't regret 32's.
mine come super close to rubbing the sway bar at full turn, but it misses. That's with a 3" bl that currently on it (yes its coming off real soon!)
post #23 of 23 Old 09-10-2013, 09:58 AM Thread Starter
Nashonater
I ended up getting 265/65/18... Which is about 32.2 inches and 11.7 inches wide. No problems with rub or bump after I set the steering stops out
2000 Jeep Grand Cherokee Limited
Nashonater is offline
jeep tj , wheels
