Quantcast stock jack.... where are the jack mounting points? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > stock jack.... where are the jack mounting points?
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 09-02-2005, 11:22 PM   #1
ADIDAS
I have no jeep manual.
I have the 3.07 gears with 31's right now.
I am going to be putting my stock wheels and tires back on (245/75/15's) monday until winter. I figure it wont kill my gas mileage as much. Bu tim not sure where to place the jack to lift it up to change them up.
Thanks.
ADIDAS is offline   Reply With Quote
Old 09-02-2005, 11:58 PM   #2
Sparty
Thanks.
I believe it's right on the axle between the LCA's and Tire.
Jeep Pics
www.msu.edu/~kerrrand/Jeep.htm
Sparty is offline   Reply With Quote
Old 09-03-2005, 12:17 AM   #3
Rocky529
Jeep
Rocky529's Avatar
An easy place is under the differential.. get both wheels off the ground at the same time.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 09-03-2005, 12:26 AM   #4
Sparty
for a stock bottleneck?
I've never done it...but I'd expect problems when doing it on the front....unless you have experience??
Jeep Pics
Old 09-03-2005, 12:35 AM   #5
Rocky529
Jeep
Rocky529's Avatar
Yea the front would give you problems I assume... the only jack I have ever used was a mechanic's floor jack. But I read that someone here did it... I forget who it was but I remember his saying that it was the jack that came with his Jeep.
Glock Forum
