stock height front bumper to ground and rear to ground - JeepForum.com
post #1 of 10 Old 04-11-2010, 06:56 PM Thread Starter
asjeep
Anyone know the stock height front bumper to ground and rear to ground on a stock tj, mine is an 02
we installed the lift and forgot to measure before
2002 TJ SE
asjeep is offline
post #2 of 10 Old 04-12-2010, 12:58 AM
BlueFlame
BlueFlame's Avatar
Measure your springs from perch to perch, and compare it with the stock measurements in the sticky thread at the top of the forum.
BlueFlame is offline
post #3 of 10 Old 04-12-2010, 02:30 AM
mJUSTINm
That method bothers me. Not all springs are equal; some are progressive, some are stiff, and some are taller than advertised. A better method would be to measure from the center of your wheel to a point on the body, like the bottom of a stock flare. Compare that to the same measurement from a stock height TJ and you'll see the lift you gained from springs alone. If you measure from ground to bumper, or ground to anything, you'll have to take into consideration the tire height.
-Justin
mJUSTINm is offline
post #4 of 10 Old 04-12-2010, 07:43 AM
Skyryder
17" front, stock '97 with 31x10.5 new and 97# of winch & stuff on the front.
19" rear with 100# of stuff (tool box, axe, etc, junk)
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
post #5 of 10 Old 04-12-2010, 08:16 AM
dualtjs
2011 JK Wrangler
How would progressive rate springs, taller springs, etc make 15" from perch to perch mean something different for 1 spring than another? 15" is 15" and it'll translate to the same amount of lift, as any other method of measurement. If it doesn't then your other measurement is wrong.
dualtjs is offline
post #6 of 10 Old 04-12-2010, 01:23 PM
mJUSTINm
Ahh I didn't see that it said from perch to perch. I thought he was talking about measuring just the spring when it's not installed. High five to a long day of driving followed by walking home in the rain and browsing JF while barely awake.
-Justin
mJUSTINm is offline
post #7 of 10 Old 04-12-2010, 02:06 PM
BlueFlame
BlueFlame's Avatar
Yep.
Measuring the height of the bumper, body, fender, door handles whatever on the rig from the ground and comparing it others is essentially meaningless, unless they also measure their tires and you account for that.
Measuring spring height tells you Exactly how much lift you achieved.
post #8 of 10 Old 04-12-2010, 02:20 PM
BigD97TJ
so probably just being retarded, but can you link that spring perch dimensions page? I too lifted my jeep without measuring. Don't really care as i like the height as is just wondering. Thanks.
BigD97TJ is offline
post #9 of 10 Old 04-12-2010, 02:23 PM
dualtjs
2011 JK Wrangler
dualtjs is offline
post #10 of 10 Old 04-12-2010, 02:36 PM
BigD97TJ
Thanks dualtjs. I guess my used procomp springs aren't what they advertise. I've got about 13.75 for the front and around 8.75 in the rear. looks like i'll be getting some different springs as the ride sucks too.
BigD97TJ is offline
94 6cyl height from ground to hood? 94MOcheen YJ Wrangler Technical Forum 4 09-16-2009 10:04 AM
GROUND POUNDER Fab Front Bumper Finally Installed Blazin Den YJ Wrangler Technical Forum 3 02-02-2009 11:51 PM
Ground Pounder Fab front and rear bumper w/ carrier TJ's Tj TJ Wrangler Technical Forum 10 07-20-2007 08:34 PM
What is the height from ground to rockers in a stock TJ? Achped TJ Wrangler Technical Forum 1 07-03-2006 10:41 PM
step in height & ground clearance ODAMO JK Wrangler Technical Forum 0 05-16-2006 09:31 PM
