Stock Fog Light Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Stock Fog Light Issue
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 02-19-2013, 03:37 AM   #1
USAF_Jeep_Dude
Hello,
I am having issues with my stock 2005 TJ fog lights. They just stopped working one day, I pulled the tab out and they didnít come on. I checked the fuses underneath the hood; I even replaced the fog relay as well but to no avail. I donít have anything to check the engine codes. I wanted to see if anyone else had the same issue before I move to the next step of replacing the switch itself. Thank you for any help you can give me.
USAF_Jeep_Dude is offline   Reply With Quote Quick reply to this message
Unread 02-19-2013, 07:27 AM   #2
esad_b
Did you check the connection upfront behind the actual fog lights? Maybe one of them lost it's ground.
Prior to this happening, did you go into the mud or cross some sort of water?
Black 05 LJ
Past 97 TJ
esad_b is offline   Reply With Quote Quick reply to this message
Unread 02-19-2013, 07:00 PM   #3
TJJP77
Before throwing parts at it, get a 12-volt test light and check the circuit for power. Start at the connectors at the lamps and see if power is getting up there. If not, work your way back through the relay and the fuse to see where the circuit is interrupted.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline   Reply With Quote Quick reply to this message
Unread 02-19-2013, 07:05 PM   #4
greene69
greene69's Avatar
Pull the cover off the steering column and make sure the multi switch isn't starting to show signs of getting hot.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline   Reply With Quote Quick reply to this message
Unread 02-19-2013, 07:34 PM   #5
jkp
The fog lights will not throw a code, however, you can check the engine codes by turning the ignition on off on off on quickly. Do not start it. Codes will display in the odo.
As stated above check for votage working your way back to the switch.
The Multi-function Switch (MFS) is a known problem child, so it is most likely your problem. If it turns out to be your MFS, you can either buy a new one, or you can install on old style fog light switch in the dash.
'92 Islander
'06 Rubicon
jkp is offline   Reply With Quote Quick reply to this message
Unread 03-21-2013, 02:42 AM   #6
USAF_Jeep_Dude
my apologies for the slow response, work has kept me way to busy to get a look the suggestions posted. I'm finally getting some time off this weekend so I will be trying the all suggestions that you all have been nice enough to post. Thank you all very much.
