stock camshaft specs? - JeepForum.com
post #1 of 5 Old 12-29-2009, 02:35 PM Thread Starter
DanZ51
Does anyone have any info on factory camshaft specs? In particular 2004, but I'd imagine any of the F.I. engines would be the same or similar.
COMP Cams - Cam Details
DanZ51 is offline
post #2 of 5 Old 12-29-2009, 03:12 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
For curiosity... why?
GOLENJEEPTJ is offline
post #3 of 5 Old 12-29-2009, 04:53 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
The stock '96 and later Jeep 4.0 camshaft is a dual pattern cam with the following specs:
Advertised duration int./exh.: 256.0/260.0 deg
Duration @ 0.050" lift int./exh.: 188.0/192.0 deg
Valve lift int./exh.: 0.408"/0.414"
Lobe separation angle: 107 deg
Intake centerline angle: 114 deg
Valve overlap (advertised): 43 deg
IVO: 20 deg ATDC (0.050" lift)
IVC: 28 deg ABDC
EVO: 16 deg BBDC
EVC: 4 deg BTDC
Sourced from here: http://jeep4.0performance.4mg.com/tech_specs.html
Another source showing almost every cam for the 4.0L/4.2L: http://www.angelfire.com/my/fan/Jeep4.0Camshafts.htm
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 5 Old 12-29-2009, 04:59 PM
never monday
changing cams won't help much
regearing is more effective
never monday is offline
post #5 of 5 Old 12-30-2009, 09:32 AM Thread Starter
DanZ51
WOW Thanks Unlimited04. I knew someone would have this info. I tried searching for this info and came up empty.
As for the other "tools".....
DanZ51 is offline
Some stock specs GIJoe Driver TJ Wrangler Technical Forum 1 08-27-2007 08:17 AM
Stock Specs for 94 YJ with HO I-6 jherrin215 YJ Wrangler Technical Forum 1 07-03-2007 02:11 PM
Stock Specs usjim YJ Wrangler Technical Forum 1 05-12-2007 08:28 PM
Stock camshaft or something more? Varnish YJ Wrangler Technical Forum 1 07-29-2005 08:20 AM
What are my specs on my stock TJ? nirres01 TJ Wrangler Technical Forum 14 08-30-2004 12:28 PM
