stock alternator amps? - JeepForum.com
post #1 of 13 Old 11-29-2010, 12:00 PM Thread Starter
leolufse
I have a 06 sport and the replacment alternators say 117 amps. I thought the stocker was 90 amps.
leolufse is offline
post #2 of 13 Old 11-29-2010, 02:46 PM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
03-06 came with 117's I believe.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #3 of 13 Old 11-29-2010, 04:59 PM
Unlimitedlou
There are several threads on here that will tell you exactly what you have. I just did the research last week and changed mine out to an 01-06 Durango which is a direct fit and 160 amps.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #4 of 13 Old 11-29-2010, 06:18 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Do you have a hard top?...
Knuckelhead is offline
post #5 of 13 Old 11-29-2010, 06:43 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Stripped down Wrangler SEs and maybe SOME Sports came with the base level 84 amp alternator but most of the Wrangler TJs came with the higher output 117 amp alternator. It's the rare TJ that has the 84 amp alternator. Especially when there are packages of options on the Jeep, and especially when there is a/c which pretty much guarantees the 117 amp alternator.
Jerry Bransford is offline
post #6 of 13 Old 11-29-2010, 07:08 PM
Knuckelhead
AFSOC Retired
Just as a note, my 2000 Sport with OEM A/C, fog lights and a soft top didn't come with the 117 amp alternator. I put a 136 amp one in from a 2000 JGC...
post #7 of 13 Old 11-29-2010, 07:15 PM
Jerry Bransford
Administrator
Don't be so sure of that. My '97 TJ's window sticker said in big letters it had the 84 amp alternator which totally bummed me out. Then quite a while later, I discovered they had buried the fact it actually had a 117 amp alternator in a separate optional package identifier. If it had a/c, I would bet it came with the 117 amp alternator which was a triggering upgrade for the 117 amp alternator.
post #8 of 13 Old 11-29-2010, 07:24 PM
Knuckelhead
AFSOC Retired
Welp, 5+ years ago I was adding some accessories and wanted more amps from my setup. I found that I didn't have the 117 amp alternator and DC wanted $300+ for one.
E-bay and $85 gave me the 136 amp one...IIRC
post #9 of 13 Old 11-29-2010, 08:35 PM
monkeee2002
Will this bolt onto a 99 4.0L without any modification?
The skinny pedal on the right is my friend. the gas gauge is not.
monkeee2002 is offline
post #10 of 13 Old 11-30-2010, 06:19 AM
Pillswoj
No, for the 99 you can get the 130 amp out of a 98 Dakota.
Friends don't let Friends run Bosch
Pillswoj is offline
post #11 of 13 Old 11-30-2010, 09:36 AM Thread Starter
leolufse
Tell me more if you don't mind. The research I did said the pulley doesn't match up and you have to modify the positive stud or something.
If this is as simple as picking up a Durango alternator and bolting it in, I'll do that today.
leolufse is offline
post #12 of 13 Old 11-30-2010, 09:42 AM
r_unda
My build sheet says 117amps but my TJ had a 90amps installed I guess previous owner changed. I just installed a 160amps this weekend. I did use the positive plastic stud frame and pulley from the old alternator. Really easy to swap.
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #13 of 13 Old 12-01-2010, 02:44 AM
bojang
Durango with a 4.7, 160 amp alternator. Should be a direct fit, it will have an extra arm on it, I did not have to mess with it, and it bolted right up to my 05.
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline
Alternator amps? cjapgar YJ Wrangler Technical Forum 4 03-02-2010 07:37 PM
Stock alternator on a 00' 2.5L TJ talus33 TJ Wrangler Technical Forum 0 11-28-2009 12:16 AM
Stock Alternator Pipedrummer TJ Wrangler Technical Forum 13 01-12-2007 06:00 AM
How many amps is the stock alternator? franco802 TJ Wrangler Technical Forum 3 04-21-2004 10:21 PM
Amps of OEM alternator igofshn TJ Wrangler Technical Forum 2 10-02-2002 11:33 PM
