Stock air box questions, 97 TJ - JeepForum.com
post #1 of 11 Old 12-03-2012, 06:39 PM Thread Starter
BigRodney
I had an aftermarket air filter and wanted a stock one. I got this used and installed it but have a couple questions. The air intake horn points right at the fan shroud. Does that look right? The way the alignment notches are designed it can only go on the box one way so it’s pointed the way it was designed but it looks wrong. Also does anyone know what is supposed to be attached to this nipple on the cover? I taped it up for now. The valve cover vents into the tube going to the intake so that’s not it. Thanks.
BigRodney is offline
post #2 of 11 Old 12-03-2012, 08:36 PM
wushaw
Rockin jeep
wushaw's Avatar
No it's not right, point it up slightly outboard or you will not like deep water crossings when the fan hits the water and you suddenly stop due to hydraulic lock of a piston.
wushaw is offline
post #3 of 11 Old 12-03-2012, 09:10 PM
bail315
The "nipple" on the air box is for the ccv tube. The design was changed after 2004 and the breather tube was moved from the intake tube to the air box. Your air box cover is from a later model. As long as your seal it well it shouldn't cause you a problem.
bail315 is offline
post #4 of 11 Old 12-04-2012, 07:38 AM
BYuen
BYuen's Avatar
You can see the minor difference in an '06 engine:
Just plug up and airbox vent and you're good to go.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #5 of 11 Old 12-04-2012, 07:50 AM
1FuddyMucker
1983 CJ7
Thats for those with a 4cylinder to hook up the nitrous line.
Don't breed em' if you can't feed em'.
1FuddyMucker is offline
post #6 of 11 Old 12-04-2012, 08:32 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If you rotate the "trumpet" as it is called enough to unlock it and pull it out, that you can reinsert it in a different position and lock it so it points upward as it is supposed to. The pic in post #4 shows the trumpet in the correct position.
Jerry Bransford is offline
post #7 of 11 Old 12-04-2012, 08:32 AM Thread Starter
BigRodney
Did ya take that picture the day you bought the jeep or do you never drive it? Nice jeep, thanks for the picture.
post #8 of 11 Old 12-04-2012, 08:35 AM Thread Starter
BigRodney
Thanks for the pictures guys. Anyone know why they changed the pcv hose location? Less venture effect, want oil to drip on the filter, could sell a longer hose? Should I update to the new design?
post #9 of 11 Old 12-04-2012, 09:32 AM
BYuen
BYuen's Avatar
Not my Jeep. I've got an '01. My engine has always like this
Probably for some kind of emissions thing. I would just keep the old design.
2001 White TJ Sport
BYuen is offline
post #10 of 11 Old 12-04-2012, 09:50 AM
prjohnson
I'd hate to have to clean that & can't imagine what the rest of the jeep looks like. I hate cleaning mud so much!
prjohnson is offline
post #11 of 11 Old 12-04-2012, 10:09 AM
tjstevo
god dam now thats a pretty lookin engine bay
tjstevo is offline
