"Stock" 32rh transmission flooded can't find breather vent - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > "Stock" 32rh transmission flooded can't find breather vent
Forever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!ORS4x4: New Product!
Unread 01-07-2010, 04:41 PM   #1
CWBRider90
I bought a used 98 wrangler with 80000 miles and the tranny had quite a few problems, I took it to the local repair shop and had a bench rebuild done it was in and out of their shop for almost a month. After the finished it I didn't have any further problems with it till I went mudding last weekend at which time my tranny filled with water, it wouldn't shift out of first gear and I had to tow it back to the shop. They said the water got in thru the breather vent and it was my fault. I disagree, I was in approx. 20 inch of water and i have a 3in lift and 31, so I don't believe i was near the vent. Can anyone with a simliar tranny tell me where their breather vent is located and if its located in the bell housing/pump how i can vent it high to avoid flooding in the future. Also what are possible side affect of water in my tranny long term?
CWBRider90 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 04:47 PM   #2
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
Here ya go...
http://www.jeepforum.com/forum/f9/re...d-auto-462033/
"It always seems impossible until it is done." -Nelson Mandela
My Epic Five-Week Cross-Country Jeep Safari
SpaceWrangler is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 05:14 PM   #3
CWBRider90
Thanks, just stumbled across that one. How do i know if I'll have any lasting side affects from the water in the tranny?
Unread 01-07-2010, 06:40 PM   #4
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Flush all the fluid, install new fluid/filter and hope...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 06:51 PM   #5
CWBRider90
That's what I figured. If there is something wrong after I flush it will I notice right away or is it just something that happens over time?
Unread 01-07-2010, 07:31 PM   #6
Knuckelhead
AFSOC Retired
You'll know right away...
Unread 01-07-2010, 07:59 PM   #7
noise_maker
Not necessarily. I flooded mine in May last year. I flushed the heck out of it and then put in new fluid as well as an external tranny filter. It shifted fine until 5 months latter when the Torque Convert completely froze up.
noise_maker is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 08:31 PM   #8
Knuckelhead
AFSOC Retired
I should have said "every transmission will have differnt results"...
