"Stock" 32rh transmission flooded can't find breather vent - JeepForum.com
post #1 of 8 Old 01-07-2010, 03:41 PM Thread Starter
CWBRider90
I bought a used 98 wrangler with 80000 miles and the tranny had quite a few problems, I took it to the local repair shop and had a bench rebuild done it was in and out of their shop for almost a month. After the finished it I didn't have any further problems with it till I went mudding last weekend at which time my tranny filled with water, it wouldn't shift out of first gear and I had to tow it back to the shop. They said the water got in thru the breather vent and it was my fault. I disagree, I was in approx. 20 inch of water and i have a 3in lift and 31, so I don't believe i was near the vent. Can anyone with a simliar tranny tell me where their breather vent is located and if its located in the bell housing/pump how i can vent it high to avoid flooding in the future. Also what are possible side affect of water in my tranny long term?
CWBRider90 is offline
post #2 of 8 Old 01-07-2010, 03:47 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
Here ya go...
http://www.jeepforum.com/forum/f9/re...d-auto-462033/
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #3 of 8 Old 01-07-2010, 04:14 PM Thread Starter
CWBRider90
Thanks, just stumbled across that one. How do i know if I'll have any lasting side affects from the water in the tranny?
post #4 of 8 Old 01-07-2010, 05:40 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Flush all the fluid, install new fluid/filter and hope...
Knuckelhead is offline
post #5 of 8 Old 01-07-2010, 05:51 PM Thread Starter
CWBRider90
That's what I figured. If there is something wrong after I flush it will I notice right away or is it just something that happens over time?
post #6 of 8 Old 01-07-2010, 06:31 PM
Knuckelhead
AFSOC Retired
You'll know right away...
post #7 of 8 Old 01-07-2010, 06:59 PM
noise_maker
Not necessarily. I flooded mine in May last year. I flushed the heck out of it and then put in new fluid as well as an external tranny filter. It shifted fine until 5 months latter when the Torque Convert completely froze up.
noise_maker is offline
post #8 of 8 Old 01-07-2010, 07:31 PM
Knuckelhead
AFSOC Retired
I should have said "every transmission will have differnt results"...
32rh transmission vent alc20754 TJ Wrangler Technical Forum 12 01-07-2010 05:08 PM
metal "rubbing" sound under acceleration 2000/4.0/32rh noise_maker TJ Wrangler Technical Forum 4 01-05-2010 08:08 PM
vent hose "cap/plug" noise_maker TJ Wrangler Technical Forum 2 12-17-2009 08:18 PM
Odd "whistle" in cabin at speed... leaky vent? windshield? other? redrockin7 JK Wrangler Technical Forum 2 01-30-2009 12:09 AM
Pic Request: TJ, 2"BB, 1" BL, 1"MML, 33x10.5", Stock Rims 04JeepTJ TJ Wrangler Technical Forum 4 07-30-2004 07:12 AM
