sticky Valves How can I free them up - JeepForum.com
post #1 of 32 Old 03-09-2008, 07:51 AM Thread Starter
robquillan
whats the best product to run through the intake or engine oil to clean my Valves up I think they are sticking Already tried sea foam through the intake -fuel-and engine oil no luck
robquillan is offline
post #2 of 32 Old 03-09-2008, 08:41 AM
Pillswoj
Jumping in to see responses, I also would like to know.
Jeff
Pillswoj is offline
post #3 of 32 Old 03-09-2008, 09:10 AM
Slithering_Joe
Sticky Valves? May I ask how you came to this observation?
4.0L TJ
Slithering_Joe is offline
post #4 of 32 Old 03-09-2008, 09:20 AM
ranger140892
You know, probably nothing really works. I run Lucas fuel treatment through my truck, Yeep, & Harley to hopefully postpone the arrival of valve deposits. I have no proof that it does anything but boost the octane a little.
As for cleaning up existing deposits, tearing down the engine is the only sure way I know. Hopefully some one will post a miracle for us all!
ranger140892 is offline
post #5 of 32 Old 03-09-2008, 05:33 PM
McJeepz
Short of actually opening things up ... the best remedy in a can that I've found is called "Sea Foam" It a pour it down the intake till it stalls / let it sit a spell / then take it for a drive somewhere so your neighbours don't hang ya tune up in a can ... makes big smoke ;0)
McJeepz is offline
post #6 of 32 Old 03-09-2008, 07:10 PM
NakedJeeper
NakedJeeper's Avatar
Old mechanics tip from an old mechanic I knew:
Change your engine oil, but use at least one quart of dexron ATF instead of oil. Its thinner and has more detergent. Run the RPMs up on the freeway. You may be able to get the lifter unstuck. Change your oil and filter again within a couple of days.
No guarantees! I have done this several times to my TJ and to my CJ with no ill effects.
NakedJeeper is offline
post #7 of 32 Old 03-09-2008, 07:20 PM
jaytee
Marvel Mystery oil did the trick on my old '89 YJ 4.2L. It started ticking at about 140K miles. I drained out my oil, bought a few quarts of the cheapie stuff and a quart of Mystery oil, ran it for about 500 miles, drained it all, did the same thing again with new oil, etc, after a couple of days on the second fill it was nice and quiet, drained it all, put normal oil in it, changed the filter (DON'T BUY FRAM!, NOT ON A JEEP MOTOR! THE FRAM SUCKS AND THE VERTICALLY MOUNTED FILTER MEANS THAT ALL OF THE BAD STUFF DRAINS BACK INTO THE MOTOR!) Everything was just fine after that!
2004 GC Laredo
1995 YJ SE
jaytee is offline
post #8 of 32 Old 03-09-2008, 08:29 PM
ThUmPeRcOn
Risoline add 1 quart in place of 1qt of oil durring your next oil change. Worked for my 03' I coud not believe it honest try it if you like this stuff has been around for 40 years and worked wonders for me. I called my father about the tick in my motor. Dad is a retired 40+ year mechanic. He asked how many miles were on the Jeep 61,000 and he said go get 1qt of risoline change your oil add 1qt in place of 1qt of oil. End of story tick is now gone. I cant remember exactally but think it has only been about 2 months since it put it in and the tick is gone. Risoline is made to clean valves etc. Yes it is a detergent but mild and from my results it works. Do a search on the www and you will find a ton of info on it if you are leary of using such things in your motor. I was too my Dad said try it and I still did a search on the stuff on the net b-4 putting it in my Jeep but now I am sold on it. Here is a link. I do not sell this stuff and in no way saying it will work for everyone but I believe I had a sticky valve and some engine gunk this cleaned it out and lubricated it. And my tick is gone.
http://www.barsproducts.com/100QR.htm
The original point and click interface was a Smith & Wesson.
ThUmPeRcOn is offline
post #9 of 32 Old 03-09-2008, 11:07 PM
ptowntj
ptowntj's Avatar
Using ATF fluid is an old trick, and it works well. run it right before your oil change and put some fresh stuff in it. It works great for my ranger which has very sticky valves towards the end of its oil change intervals.
8 lug xj.
ptowntj is offline
post #10 of 32 Old 03-10-2008, 12:20 AM
Axl Jack
I've heard this from a mechanic at a Subaru dealership as well. Being a mechanic at Birney Honda in Scranton, PA, however, I would NOT recommend this on any Honda engine.
Jeeps.... I dunno. ha ha
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #11 of 32 Old 03-10-2008, 12:21 AM
xxxflhrci
xxxflhrci's Avatar
Your valves can't "stick". The valves are opened up by the pushrod which is lifted by the lifter running on the cam lobe. About all that can happen is a hyrdaulic lifter can not pump up fully either due to wear or the oil hole getting clogged. When that happens, they tick. Sure, a miracle in a can, like Risoline, Seafoam or ATF may sometimes help with a lifter that is bleeding down, but most of the times not. Then,the problem can be traced to a worn part, either the lifter, rocker arm, pushrod or cam.
xxxflhrci is offline
post #12 of 32 Old 03-10-2008, 01:16 AM
ranger140892
You guys need to help me out here. How do you know your valves are "sticky"? You can't see, or feel them. Are you hearing something? The push rod is gonna move them no matter how sticky they are. Or break. And where is it sticking at: Seats or guides?
I can understand how some type of additive put in the intake would maybe clean the seats but not the guides. And v/v on oil additive.
post #13 of 32 Old 03-10-2008, 01:18 AM
Greg_Volkman
I wouldn't ever drive with the ATF in the crank. I have drained a quart of old oil, poured in a court of ATF, let it idle for 10 mins, then drained it all and replaced the oil/filter.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline
post #14 of 32 Old 03-10-2008, 01:36 AM
ranger140892
That reminds me: Years ago an old fart told me to do that in my 77 Bronco. So I did it without question. The next day the rear main, and timing cover were leaking oil. That was back in the day when I had to drive 40 miles to the nearest parts store, then come back 4 days later when the parts came in.
post #15 of 32 Old 03-10-2008, 06:06 AM
barty
Even if you keep it in there for the full duration of the oil change, it shouldn't cause any problems. It is roughly the same as 5w-30 oil so I have been told. I found this out after an acquaintance dumped about 2 quarts of ATF in their engine. I asked around and the general consensus was that it wouldn't hurt anything if the motor didn't have a ton of mileage on it.
Any seal leakage is from the detergents breaking down the crud that tends to build up around the gaskets and seals and not because ATF is doing anything sinister to the seals themselves.
barty is offline
help with valves psycopanther TJ Wrangler Technical Forum 3 08-13-2007 08:58 AM
sticky sticky brakes! jeep25tj TJ Wrangler Technical Forum 6 04-10-2007 09:56 PM
Two Pcv Valves jaysky YJ Wrangler Technical Forum 6 10-20-2006 02:53 PM
do you need 2 pcv valves? whyjay YJ Wrangler Technical Forum 2 01-05-2006 02:36 PM
4.0 valves ryanxj YJ Wrangler Technical Forum 10 08-05-2003 10:29 AM
