Quantcast Sticker Removal (on plastic windows and paint) - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Sticker Removal (on plastic windows and paint)
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 11-07-2006, 10:17 AM   #1
beertinted
I just tried little 'goof-off' on a sticker on the paint of my jeep, but it didn't really do much. It recommends rubbing it with a brush, but that wouldn't work on the paint - any products/ideas/techniques you guys use to get crappy stickers off?
Also, what do you use on the plastic windows to get stickers off of those?
(No, I didn't put the stickers on, it came that way )
beertinted is offline   Reply With Quote
Old 11-07-2006, 10:19 AM   #2
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
zippo fluid.
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
Feed my girlfriend.
Follow my girlfriend
Brew what you drink, drink what you brew
USN Hull number 54
Poor Boy is offline   Reply With Quote
Old 11-07-2006, 10:19 AM   #3
TJ on the Rocks
WD-40 works well for both , the painted surfaces & the windows .
A plastic scraper or the edge of a credit card helps once the adhesive is soft enough .
[SIZE="7"][SIZE="7"][SIZE="5"][URL="http://www.atozfabrication.com/catalog/"][B][CENTER][SIZE="5"][COLOR="Red"]AtoZ F[/COLOR][COLOR="White"]abric[/COLOR][COLOR="Blue"]ation
[/COLOR][/SIZE][/CENTER]
[CENTER][B][/SIZE]
[SIZE="4"][/URL][/B][COLOR="Red"][/SIZE][/SIZE][SIZE="3"][URL="http://www.stickylee.com/catalog/index.php"]www.stickylee.com[/URL][/COLOR][/SIZE][/B][/CENTER][/SIZE]
TJ on the Rocks is offline   Reply With Quote
Old 11-07-2006, 10:19 AM   #4
UCTJ
Ive used Sticker Shock before and it works very well. I dont know if your able to use it on plastic windows or not but check it out at your local parts store.
UCTJ is offline   Reply With Quote
Old 11-07-2006, 10:49 AM   #5
stevensinger
stevensinger's Avatar
Originally Posted by TJDegenerate
zippo fluid.
x2 I have used this on many thing, Lighter fluid doesn't hurt paint and if you need to try mouth floss to get under the sticker and SLOWLY shimmy it side to side.
stevensinger is offline   Reply With Quote
Old 11-07-2006, 10:59 AM   #6
Combatsylvania
Lighter fluid isnt good for paint, it can be used a paint thinner actually. Small doses would be okay, but rinse off immidiately.
I would suggest using rubbing alcohol to remove any left over goo, or try a product called googone
The dental flass trick is a good one, try heating the sticker with a hair dryer or heat gun first.
I've also read threads where people heat a face cloth in boiling water then quickly (using tongues) apply it to the sticker. This losens the adhisive a bit, peel ith with dental floss, and clean it up with alcohol.
Note: rewax after this, as most of the products will remove wax aswell as the sticker goo.
Combatsylvania is offline   Reply With Quote
Old 11-07-2006, 11:02 AM   #7
ColoradoTJ
Use a hair dryer and then your finger nail. I took off the Wrangler and 4.0L stickers off by apply heat from the hair dryer and then picking at the corners with my finger nail. Once I could get a hold of a corner the stickers peeled rite off.
Clint
Colorado Jeep Club Member #60
My Jeep
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline   Reply With Quote
Old 11-07-2006, 11:16 AM   #8
beertinted
great tips, everyone! thanks, I'll go experiment now... (Don't have a hair dryer though)
Old 11-07-2006, 05:50 PM   #9
beertinted
Wow - WD-40 worked really well! it took 'em all off easily - one I had to use a razor blade for, but there are no ill-effects - thanks!
Old 11-07-2006, 05:53 PM   #10
TJ on the Rocks
[CENTER][B][/SIZE]
Old 11-07-2006, 06:11 PM   #11
Millertime06
yep thats money right there, thats kinda what I did to get my ugly freedom stickers off.
03 Freedom X
33 Pro comp muds on pro comp alloys, RE BB, 1" PA BL, Rancho SS, W/S Daylighters, Olympic grille guard, Rock crawler rear bumper with tire swing, KC Back up Flood lights, some sound stuff - SOLD =(
Millertime06 is offline   Reply With Quote
Old 11-07-2006, 06:30 PM   #12
Dr. Marneaus
Hairy Armgina
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
i bet this isnt great for yer paint, but in quick doses, nail polish remove works wonders. used itt o take off the mounting tape from the emblems on my maxima.
Andrew - Landscape architect in training. Not landscaper
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
"One of the best ways to get yourself a reputation as a dangerous citizen these days is to go about repeating the very phrases which our founding fathers used in the great struggle for independence" - Charles Austin Beard
OOoooh, it's a killin' machine! It's got everything! Like a drivin' power, big fat tires, and everything!
- Deep Purple
The Beast Build Thread:Marns '73 Wagoneer Thread ----- Gone but not Forgotten:97 TJs Build Up.
Dr. Marneaus is offline   Reply With Quote
Glock Forum
