Steering wheel 'wobble' at 45-50 MPH - JeepForum.com
post #1 of 16 Old 07-14-2005, 11:59 AM Thread Starter
MikeWL
MikeWL's Avatar
I noticed recently that between 45 and 50 MPH I get a shimmy/shake/wobble in the wheel. Going absolutely straight, it's not there, but just put a bit of twist on the steering wheel in either direction and it shakes back an forth.
Any ideas? I don't think this is what others have referred to as "Death Wobble", but I'm not sure. I am taking it in for tire balancing and alignment this weekend, but thought I would ask first so I know what the real experts think.
[B]2001 TJ Sport - 4.0L/5-sp, locked Dana 44's, 4.10, 33's, Mile Marker; 2000 TJ Sport RIP
MikeWL is offline
post #2 of 16 Old 07-14-2005, 12:02 PM
Rommel
Rommel's Avatar
The tire balancing/alignment should fix all your problems unless you have damaged wheels.
-Romm
"A dreamy horse! This is my 4th jeep since I first drive 12 years ago. I just drive jeep, always..." - Red Bull China
Rommel is offline
post #3 of 16 Old 07-14-2005, 12:17 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
An alignment won't help, it's either a bad tire, an out of balance tire, or the wheel is bent or damaged.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Jerry Bransford is online now
post #4 of 16 Old 07-14-2005, 07:46 PM Thread Starter
MikeWL
MikeWL's Avatar
I hope you're right. I've never had a tire so out that it caused the steering wheel to have a rotational vibration, but it sounds reasonable. The weird thing is that I don't feel it anywhere else (dash, seat of the pants, floorboard, shifter, etc.) I'll report back after the balancing.
thx again.
MikeWL is offline
post #5 of 16 Old 07-14-2005, 07:49 PM
zachman
I had the same problem on my TJ, I changed the track bar, and got a adjustable one from teraflex, that solved the problem, I have a 2" lift on my jeep.
zachman is offline
post #6 of 16 Old 07-14-2005, 08:03 PM
TheDuke05
TheDuke05's Avatar
I had the same problem after my lift. I changed out the front driverside tire with the spare and...problem solved. Also check that the trackbar is tight (75 ft-lbs, I think).
"You don't have to flaunt your sucess, but you don't have to apologize for it, either"-- Gene Stallings
Sold my Jeep earlier this year. Kinda miss it but I love my Infiniti.
TheDuke05 is offline
post #7 of 16 Old 07-14-2005, 08:06 PM
powerstroke01
powerstroke01's Avatar
2005 WK
Ive got the same problem. Im just gonna rotate my tires and see what it does.
Jeepers do it in the mud. ;)
powerstroke01 is offline
post #8 of 16 Old 07-14-2005, 11:54 PM
Jerry Bransford
Administrator
The loose trackbar didn't cause the vibration, it merely allowed it to develop. Trackbars don't by themselves start vibrating... but tires and wheels do and when the trackbar is loose, it can let the front-end start shimmying even to the point of Death Wobble. Replacing the trackbar with a newer one only masked the symptom like holding down something tighter that was trying to move around on its own. Let go and it starts up again.
post #9 of 16 Old 07-15-2005, 08:04 AM
spinnjase
i just installed a BB, 1" BL and MML. for the first couple of days i had the tires i'd been using for a year (31" bfg at) and everything was ok. when i put the 33's on, then i started getting a wobble at about 45mph. my rear tires are new, but the fronts are used. i guess i'll try the self-alignment write-up on 4x4xplor. if that doesn't fix it, i'll have to wait and see if new front tires will fix it. hopefully it's not one of my new wheels outta whack.
J
spinnjase is offline
post #10 of 16 Old 07-15-2005, 02:45 PM
jonballi
I had the same thing...after 1pprox 16k miles on the factory tires.
The FIX:
Balanced the tires.
jonballi is offline
post #11 of 16 Old 07-15-2005, 09:34 PM
spinnjase
got an alignment tonight, that didn't fix it. i'm going to go back to where i got the tires mounted and balanced and make em redo it.
J
post #12 of 16 Old 07-15-2005, 10:37 PM
The Diver
The exact same thing happened to me the other day. I drove straight to the tire shop and had them rotate and balance the tires. Fixed it.
Alan
The Diver is offline
post #13 of 16 Old 07-16-2005, 05:53 AM
swoodnj
swoodnj's Avatar
Just went through the same thing, balancing and alignment didn't help, but one tire was worn unevenly, replaced that and all is well.
04 TJ X 4.0L 5 spd
Bright Silver Metallic Clear Coat Exterior Paint Club member #18
swoodnj is offline
post #14 of 16 Old 07-16-2005, 07:12 AM Thread Starter
MikeWL
MikeWL's Avatar
Looks like balancing fixed it. Yeah. thx again.
MikeWL is offline
post #15 of 16 Old 07-16-2005, 09:50 AM
jonster
jonster's Avatar
2014 JK Wrangler
I was going to start the same, identical post. Now don't have to. I noticed my 'shimmy' right after I took out my 2" spacers and installed 2 1/2" springs. I did the 'doityourself' alignment and adjusted the track bar also. Still got the slight 'shimmy'. Next is the re-balancing.
2014 White JKUR
jonster is offline
Do wheel spacers make your steering wheel wobble at high speeds? bgndobe TJ Wrangler Technical Forum 22 07-20-2009 08:27 AM
New wobble in steering wheel. Help gsxr150 TJ Wrangler Technical Forum 10 08-23-2007 01:25 PM
Steering Wheel Wobble. Not Death Wobble. bigbarr TJ Wrangler Technical Forum 1 05-29-2007 12:29 PM
Steering wheel wobble BMdeckie TJ Wrangler Technical Forum 1 12-29-2006 12:30 PM
Steering Wheel Off & Wobble Avor TJ Wrangler Technical Forum 6 09-08-2003 11:39 AM
