Steering Wheel Squeak - JeepForum.com
post #1 of 4 Old 12-03-2003, 10:02 PM Thread Starter
drzima
drzima's Avatar
Looking for some info no a Noise I just started noticing since it started getting COLDER here. Seems everytime I make a hard right or left turn my Steering Wheel is creaking or squeaking. Doesn't seem like a big problem. Checked Fluids and everything looks fine. It actually sounds like it is coming from the inside of the Jeep. Any Ideas? not sure if this is a easy fix or not. Thanx.
Dan
'you only live once, do it while you're still here"
'98 Wrangler 4.0L Sport
'06 Harley Davidson Deluxe
drzima is offline
post #2 of 4 Old 12-03-2003, 10:05 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Spray the steering shaft with a silicone lubricant where it passes through the rubber bushing in the firewall. Spray it from the passenger-compartment side. This is a common problem that the silicone will fix, at least for several years when it will need to be done again.
Jerry Bransford is offline
post #3 of 4 Old 12-03-2003, 10:06 PM
JPTJ06
JPTJ06's Avatar
Yeah my 97 is doing the same thing. I was gonna post the same question yesterday but forgot. I'm not worrying about it too much, unless somebody else says otherwise.
Jimmy
97 Sport 5sp, 2"BB w/DT3's, AR-767, 32" Mud Rovers
01 Sport 5sp, stock
03 Rubicon
JPTJ06 is offline
post #4 of 4 Old 12-03-2003, 11:24 PM
RckyMtnTJ
Do exactly what Jerry says and you will have no more squeak. Nothing will be harmed if you don't get around to lubing it anytime soon.
98 TJ with some stuff
RckyMtnTJ is offline
Steering Wheel squeak in winter marko686 TJ Wrangler Technical Forum 18 02-24-2011 09:42 AM
squeak from steering wheel, and feedback? jaminb YJ Wrangler Technical Forum 0 02-04-2008 02:33 PM
Steering Wheel Squeak??? JYogi JK Wrangler Technical Forum 2 01-07-2008 11:10 PM
Anyone's Steering Wheel Squeak? burchdog32 TJ Wrangler Technical Forum 13 05-08-2007 02:17 PM
steering wheel squeak blang4d TJ Wrangler Technical Forum 3 12-01-2005 10:34 AM
