steering wheel squeak - JeepForum.com
post #1 of 4 Old 12-01-2005, 06:13 AM Thread Starter
blang4d
When I start up my jeep (97 TJ) and start off to work in the morning, I've noticed a squeak coming from the steering wheel/column when I turn the wheel. This only happens when everything's cold. When the engine/pass. compartment warm up, the squeak goes away. Does anyone know what is causing this/how it can be eliminated? I know WD40 is great for eliminating squeaks like this, but I don't want to just go spraying it around the clockspring, airbag wires, etc. if I don't know what I'm doing.
Thanks
blang4d is offline
post #2 of 4 Old 12-01-2005, 06:56 AM
99TJSport
99TJSport's Avatar
You need to spray some white lithum grease around the boot that seals the firewall where the steering column passes through. Put some between the boot and the firewall and it should stop your noise. Believe it or not, there is a TSB from Jeep about this problem, and what I described is the "offical" fix for the problem.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline
post #3 of 4 Old 12-01-2005, 07:24 AM Thread Starter
blang4d
Don't ya just love how they come up with such highly advanced ways to fix stuff?
Thanks for the info.
blang4d is offline
post #4 of 4 Old 12-01-2005, 10:34 AM
JoonHoss
2011 JK Wrangler
read this for help and explanations:
http://www.jeepforum.com/forum/f9/moaning-when-turning-steering-wheel-203073/
congrats... you're not alone.
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
Steering Wheel squeak in winter marko686 TJ Wrangler Technical Forum 18 02-24-2011 09:42 AM
squeak from steering wheel, and feedback? jaminb YJ Wrangler Technical Forum 0 02-04-2008 02:33 PM
Steering Wheel Squeak??? JYogi JK Wrangler Technical Forum 2 01-07-2008 11:10 PM
Anyone's Steering Wheel Squeak? burchdog32 TJ Wrangler Technical Forum 13 05-08-2007 02:17 PM
Steering Wheel Squeak drzima TJ Wrangler Technical Forum 3 12-03-2003 11:24 PM
